09-25-2020, 06:21 PM | #1 |
2010 RS
Drives: 2010 v6 Join Date: Jul 2015
Coolant temp reached 250 degrees in traffic today
Coolant temp stays between 190-210 while moving, but quickly goes up when stopped. Fans don’t cut on until like 240 degrees. And my temp needle on the dash stays well below halfway even at up to 220 degrees shown on dash and then went to halfway and a little beyond at 250. I just added coolant last week and I’m low again. And even when I hit 250 degrees I didn’t get a temp Warning message on dash.
I have a thermostat ready to replace but I can’t find any info on how to do it |
09-25-2020, 06:22 PM | #2 |
Evil Genius of Chevrolet
You tube
09-25-2020, 06:23 PM | #3 |
If you're loosing fluid I would get it pressure tested first though.
09-25-2020, 06:26 PM | #4 |
2010 RS
09-25-2020, 06:48 PM | #5 |
Drives: 2011 Camaro 2ss Convertible Join Date: Jan 2020
09-25-2020, 07:17 PM | #6 |
Well the clue here is that you had to add coolant already. I would be concerned about a leak, cracked radiator, or worse - a head gasket. But let's not go there just yet.
Just for the sake of caution, have you checked your oil level and quality? Just make sure it still looks like oil and not pudding or a frothy mess. Also, when you overheat like this your oil change interval will set itself to zero, at least it will on the V8s, not sure about the LLT or if 250º would trigger it. On the V8 Camaros you get 2 levels of overheating warnings. The second one puts you into reduced power mode. Again, not sure how it is with the LLT/LFX. Either way, once you get this figured out you need to get that oil changed as overheating the engine cooks that oil and drastically reduces it's life.
09-25-2020, 07:25 PM | #7 |
Drives: 2010 Camaro 2SS Join Date: May 2016
Check this out.It might be the problem or not.But it’s a place to start
https://www.camaro5.com/forums/showt...ght=Block+leak |
09-25-2020, 08:49 PM | #8 |
Drives: 2012 Victory Red LFX Join Date: Dec 2012
No sign of leaking coolant?
No smell? 10 year old hoses might be the culprit but it isn't beyond reason for a crimp to be leaking on the rad. I have picked up the habit over the years to either park where a leak would be obvious on returning to said spot or in the case of my Camaro drip mats underneath. Eight years and the Camaros never leaked but my DD just had a wheel brake cylinder let go and I caught it the next day.
09-26-2020, 08:36 AM | #9 |
376 cubic inches of fun
If your system is not holding pressure, the boiling temp of the coolant is too low and it's boiling off.
It's not necessarily the case that you will see a puddle under the car when this happens, because the coolant is leaving as vapor. Pressure test is the obvious first step, as others have said. If the system is pressurized, you don't need to add coolant for YEARS. |
09-26-2020, 05:28 PM | #10 |
Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
Possible head gasket leak. That was my issue with low to no coolant in the overflow tank.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
09-26-2020, 05:44 PM | #11 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Where did you add coolant.... reservoir or radiator? Last time you checked it.....changed it?
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
09-26-2020, 09:01 PM | #12 |
2010 RS
Went to replace the thermostat today which was probably the hardest job I’ve maybe ever done and found my housing is broken where the thermostat is supposed to be held in
I am assuming this is my issue |
09-26-2020, 11:41 PM | #13 |
Let's hope so. Make sure you get it pressure tested after your done to confirm or find the issue.
11-27-2020, 03:18 PM | #14 |
Drives: 2017 Camaro 2SS, 2011 Camaro 2LT Join Date: Jan 2014
Did you fix the issue? If so, what were the steps on getting to the thermostat?
