08-30-2020, 01:14 AM | #1 |
Car shake after replacing tires
My tires needed to be changed I have 20x9 front with 245s, and 20x10 in the back with 275s, got great deal on a used set they're barely used but I put 265x40 and 315/35, not sure if its the tires size or cuz my old ones needed to be replaced but the ride got really REALLY comfortable on the road, however on higher speeds like 60mph the steering wheel shake a lot, also happens the same when I hit the brake, what could be the problem? Is it the new size or just needed balancing or something?
08-30-2020, 07:29 AM | #2 |
Fast Cars and Old Guitars
It could simply be imbalance. Some stores don’t calibrate their balances as regularly as they should. But...if it’s a crappy, out-of-round tire or set, they’ll balance out on the machine but there is no fixing the vibration when they roll on the road.
08-30-2020, 07:54 AM | #3 |
Drives: 13 Camaro 2SS/RS LS3 Join Date: May 2020
It most likely is the size difference. With your setup there's a difference in diameter, sidewall, and circumference. Go on any tire size calculator website and input your info you'll see the difference. Try to find 275/40 tires for the front or go smaller and you'll be good. I'm running 275/40/20 and 315/35/20 good luck.
K&N Intake/ Pray Ported TB/ GPI Rod-Mod Intake Manifold/ GPI Ported Heads/ GPI SS3 Cam/ TSP 1-7/8" LTH to NPP/ Z/28 Diff/ Hendrix Offset Bushings/ BMR Delrin Cradle Bushings/ Pedders 27/32mm Sway Bars/ 1LE Shocks & Struts/ BMR 1.25 Springs/ Mishimoto Catch Can
08-30-2020, 08:19 AM | #4 |
Drives: '10 Camaro SS,Jeep Commander Hemi Join Date: Mar 2010
sounds like it's the balance OR your lugs got tightened too much and warped your rotors,the size of your tires aren't that far off,circumference of the 265's is 89 and the 315's is 90.the revolutions per mile is 703(315's) and 711(265's),sidewalls are,4.34 & 4.17,Also,have the tires checked for shifted belts.
Good Luck! |
08-30-2020, 08:45 AM | #5 |
Drives: 2014 Camaro RS 2LT convertible Join Date: Jul 2020
Did you balance the front wheels when you put the new tires on?
Warped rotors from not applying an equal torque on the lugs. For the folks saying the wheel diameter is a consideration- why? If the the left and right pairs match in size, what is the issue with front and back having different diameters? |
08-30-2020, 09:46 AM | #6 |
Drives: 2010 RS Inferno Orange Metallic Join Date: Mar 2010
I had this problem, It was they needed to be road balanced. the bigger tires need a special balance. I bought the tires used and they did balance them on there machine.
Mine would vibrate badly when i got up to 65 - 75 I just took mine to a good shop and had them road balanced. I watched them do it, it was kinda different, they would mount the tire run it and then the machine would tell them to rotate the tire around the rim a little or a lot. This might take a couple of trys. Then they balanced it the last time with weights
PCP Hideaway Headlight Covers, BBK Headers & High Flow Cats, ZL1 Add-ons Wicker Bill, TL1/ZL1 Hood Insert, Gen5 DIY Frameless Mirror, ABL Dash Lighting an My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller, Heritage Grill, Diode Dynamics Led Lighting, Manual Shifter Boot, Paddle Shifters, CNC Throttle Body, Trifecta Tune, RX Catch Can & Breather, Trunk Black out and Side Grills, Chevorlet door Sills.
08-30-2020, 09:48 AM | #7 | |
And the Pattern on the tire was Crazy.
08-30-2020, 12:30 PM | #8 | |
This is what's happening to me, glad to hear it's fixable without having to go lower on the size cuz I really like the look and comfortablity of these, i'll have them checked out at a decent store thank you!
08-30-2020, 12:33 PM | #9 |
The ones I got are the nittos they're late 2019 and the fronts are continental, I got all of them for like $150 which is something incredibly amazing but then again this is the price range in Dubai, everything is cheap around here!
08-30-2020, 02:04 PM | #10 |
While it may be Road Force Balancing that is needed, you need to consider the other possibility....Why were these tires discarded by the previous owner?
Buying used tires always involves a risk. Not judging, I have had to do it multiple times, even on this car. But I got lucky each time, knowing that the issue you are dealing with was always possible.
08-30-2020, 04:38 PM | #11 | |
376 cubic inches of fun
Some tires are so defective that road force balance won't fix them. The idea behind road force balance is that it compensates for irregularities in sidewall stiffness, but there's a limit to what that correction can do. I had a brand new van once with terrible tires from the factory. Road force balance did nothing to fix the shake. It was a waste of money and I got no satisfaction from the tire warranty either. At the time, i couldn't afford to replace the tires so I drove on them until they wore out. New tires: problem solved. Buying used tires? No way. |
08-31-2020, 06:47 AM | #12 |
Drives: 2018 1SS M6 Join Date: Nov 2014
Add that those tires are WAY oversized for the wheels you have them on. Balancing can be an even greater challenge.
08-31-2020, 11:17 AM | #13 |
Drives: 2013 2SS/RS Join Date: Nov 2015
I'm confused. 265 is the correct size for his 9" front wheel, and 315 is just slightly oversized for his 10" rears. He should have zero issues running those tires on his rims. Unless he has factory rims and is quoting the wrong rim size.
08-31-2020, 11:22 AM | #14 |
Check for bubbles.
