08-20-2020, 01:31 PM | #1 |
Drives: 2011 camaro 2 SS Join Date: Jun 2019
ticking noise
Hey guys ive got a 2011 Camaro SS L99. on cold start up theres a ticking noise that only lasts for about 2 seconds, then i dont hear it again. sounds like valve train but not sure how worried to be about it
08-20-2020, 02:09 PM | #2 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
mods? could be the start of an exhaust leak...how many miles on the car?
l8tr PEACE
08-20-2020, 02:21 PM | #3 | |
It is possible that lifter is going bad and has to pump up, but start with the exhaust.
08-20-2020, 02:50 PM | #4 |
Wife named it "Ghost"
Drives: 2012 Camaro Summit White 2SS/RS M6 Join Date: Jan 2017
Seems like a lot of LS motors with age seem to have lifters get a little sticky or bleed down as the oil thins out. I have a 2000 GMC with a 6.0L with 130K miles on it and it will be a little noisy/ hear small tick at startup. I know these motors are really different, but I've done a few things that have helped stop it on the truck. I have done the seafoam and that helped a bit, but I've also added a little bit of marvel mystery oil and then the Lucas oil additive and it doesn't do it any more. Anyone have any other experience trying that on the LS3 or L99? Kinda old school, but Might give it a try to see if it helps.
2012 2SS/RS Camaro M6 Summit White
08-20-2020, 05:08 PM | #5 |
Drives: 2010 2SS RS LS3 Join Date: Jul 2017
If the ticking/knocking sound is coming from the rear, you may have the dreaded "Trunk Monkey".
Hopefully that is the root of the ticking. |
08-20-2020, 06:48 PM | #6 |
Drives: 2011ss/rs camaro Join Date: Sep 2011
Sounds like the dreaded afm lifters. Some Early L99s Have/had faulty lifters that would leak down. Tic tic tic on startup until the lifters pumped up. Usually within a few seconds. Doesn’t do it every time but randomly. Some had there’s replaced under warranty...me being one of those.
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
08-21-2020, 06:50 AM | #7 | |
Drives: SUMMIT WHITE 2SS/RS CAMARO Join Date: Feb 2008
My early 10 L99 lifters have never made a sound after 11 years. The trick is to change your oil frequently. I've changed mine 16 times in 62,000 miles. Also, there's nothing dreaded about it. It does no harm imo.
08-21-2020, 09:15 AM | #8 | |
2010 2SS living in Los Angeles
replaced engine @ 93,000 miles w/ crate engine, camshaft by Comp Cams installed by me, replaced valve train parts, 1.4" BMR lowering springs ZL1 factory rims misc: drilled and slotted rotors, fresh air brake cooling system, new speakers, installed reverse camera, muffler delete |
08-21-2020, 11:58 AM | #9 |
Like Said you got to keep the oil clean.
08-23-2020, 11:41 AM | #10 |
Thanks guys i can always count on good suggestions when i have a question. Keep it up
08-23-2020, 12:18 PM | #11 |
Maybe nothing, but what oil filter are you using?
Thinking a cheap filter and drain back valve inside leaking? Corrections welcome.
09-18-2020, 11:59 PM | #12 |
Drives: 2011 2SS/RS Victory Red Join Date: Aug 2011
BTR fixed my L99 ticking noise, but now it has this weird lope to it and the car shakes at idle...
Updates: BTR Stage 2 VVT Cam Kit w/Smith Brothers Trunnions, Fluidampr, RX catch can, B&M Trans pan mod, Kooks Black Headers, Borla S-tunes, Eibach Multi-Pro-R2 coilovers and Swaybars, BMR Full Bushing kit with Toe and Trailing arms, RB Rotors w/EBC Pads, GForce 1400 Axles (now on order). AVH-X5800BHS in Scosche GM5201AB. |
