08-05-2020, 12:13 PM | #1 |
lost between two shores
Drives: 2020 SS 1LE Join Date: Apr 2018
Anyone NOT Happy w/ Secondary Cat Delete?
I've taken pride in this being the first of a long list of cars that I've felt needs no mods (2020 1LE). However, after owning for nearly a year I'm considering a secondary cat delete just to give what I already like a little more icing on the cake.
I'm just curious if anyone's done this mod and wish they hadn't because it made changes they didn't like, such as too raspy, a little bit of drone, etc.
2020 SS 1LE | Almost Mod Free
08-05-2020, 12:22 PM | #2 |
Drives: 2016 2SS Join Date: Apr 2020
It'll be a bit louder. I haven't come across anyone that has regretted doing it. The primary cats will make the car considerably louder, but will also require a tune.
08-05-2020, 12:48 PM | #3 | |
Drives: SS A8, NPP, Red Hot Join Date: Jan 2019
08-05-2020, 01:13 PM | #4 |
I get what you're saying, but I've spent too much time and money in the past experimenting with various mufflers, headers, high flow cats, etc. I plan to either leave this stock, or delete the secondary cats. Just curious if anyone wasn't happy with the change (other than those that had weld leaks).
08-05-2020, 01:33 PM | #5 | |
08-05-2020, 01:48 PM | #6 |
Yes, and I keep it locked in Track Mode, so the valve is always open.
08-05-2020, 01:54 PM | #7 |
08-05-2020, 01:57 PM | #8 |
Drives: 2020 Camaro LT1 Join Date: Jul 2020
08-05-2020, 03:27 PM | #9 |
When does it close? In Track Mode it never sounds as quiet as Stealth Mode, which is when the valves are closed.
08-05-2020, 03:40 PM | #10 |
Drives: 2020 Camaro 1SS 1LE Join Date: Jan 2020
I agree with Idyll. I don't think it ever closes with track mode. I read it does when off throttle but I've played with other modes and in track it still remains very loud with crackles and pops off throttle in track. I can def hear a difference from tour mode off throttle. They must of reprogrammed them in 2019-2020 because I feel like people who have pulled the fuse in newer cars don't notice a difference at all. Also having the same debate btw. I want to delete the secondary cats because I love the sound but want it a little louder. Also the factory suitcase acts as the rear diffuser.
08-05-2020, 03:55 PM | #11 |
Drives: 2016 Camaro 2SS Join Date: Apr 2017
It closes a little at highway speeds. I could hear a difference when testing. I could be wrong....I might've only tested sport mode. Cant remember. So, I just kept fuse 51 out.
2016 2SS, MRC, NPP, A8. Procharger P-1X,Stage II,std bypass, 3.9, Alky Meth - 10.84 @129 - DA+2000
New Mods - GPI drop ins, Kooks 2", LT4 fueling, Cam, Circle D Converter, 3.5 pulley & dual nozzle meth. |
08-05-2020, 05:12 PM | #12 |
As Grampa_ss said, they typically close when driving at the highway or just cruising in general. Once you start to hit the gas the valves will open right back up!
08-05-2020, 06:03 PM | #13 |
Drives: Camaro SS 1LE Join Date: Aug 2018
Yes I believe they close at highway speed‘s also. I plan on secondary cat delete also.
08-06-2020, 04:38 AM | #14 |
Drives: 2019 2SS 1LE Join Date: Aug 2019
My 2019 track mode closes valves under light throttle below 1500rpm at all speeds as well as under light throttle at highway speeds above 1500rpm.
