Old 08-02-2020, 08:09 PM   #1
LS3_JC
LS3_JC's Avatar
Drives: 12’ Chevy camaro SS 6MT
Will 20x10 ET23 wheels fit
So I’ve been looking to buy a new set of wheels and found the factory reproductions 27 (z28 replicas), there are 2 options for offset: +35 and +23. I’m trying to make the wheels go flush with the fender. If it helps My car is a 2012 Camaro SS with the stock Brembos, stock Suspension (gonna go with coilovers) soon). Also the full specs for the wheels are: 20x10 ,ET+23 ,5x120.65 ,66.9. Same for the other ones except it’s a +35 offset.
LS3_JC is offline   Reply With Quote
Old 08-02-2020, 10:20 PM   #2
Athletics101
Athletics101's Avatar
Drives: 5th Gen L99
20x10 +35 can fit on all 4 corners, tho I haven’t done it. It’s a size guys run with the TSW’s. I know certainly that a 10 inch wide wheel with 35mm offset sits flush in the rear as that’s my current set up on my radials.
LSA conversion 2.5 upper 10% lower, L99 converted to LS3. TSP 229/244 cam, TSP LS3 ported and milled heads milled .015,Kooks LT’s no cats, Roto Fab, Borla arak cat back. 3200 stall,Forgestar F14 18’s and drag radials, pedders coil overs, BMR trailing arms & adjustable toe rods, mildly stripped Interior 685/613 on E 610/571 on 91
Athletics101 is offline   Reply With Quote
Old 08-02-2020, 10:40 PM   #3
LS3_JC
LS3_JC's Avatar
Also will the 5x120.65 bolt pattern fit?
Old 08-02-2020, 11:13 PM   #4
Athletics101
Drives: 5th Gen L99
Absolutely.
Old 08-02-2020, 11:22 PM   #5
Vegas Bound
Drives: 2013 Sparkly Red One
0.65 is 26/1000 of an inch.
Old 08-03-2020, 07:34 AM   #6
steakmaker
steakmaker's Avatar
Drives: '10 Camaro SS,Jeep Commander Hemi
I had a square set 20x10 +34 no problem,until they got stolen that is!
steakmaker is offline   Reply With Quote
Old 08-12-2020, 04:19 PM   #7
SSkat
SSkat's Avatar
Drives: 2010 Camaro 2SS
I ran a 20x10 +25 squared with 275/315 tires and it fit fine with no spacers or anything. It poked a little but not much. I liked it better in the rear more than my current 20x11 +43.
SSkat is offline   Reply With Quote
Old 08-12-2020, 05:20 PM   #8
SSEssence
Instagram: Sangstah
SSEssence's Avatar
Drives: 2019 Camaro 1LE
I'm running 20x10 +25 up front w no issues or rubbing.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717
SSEssence is offline   Reply With Quote
Old 09-14-2020, 09:18 PM   #9
jksynergy
jksynergy's Avatar
Drives: 11 SW SYNERGY SERIES/14 1SS 1LE
Yes, they will fit.
Both of these sets are 20x10. Gray wheels are et +35. The polished and brushed set is et +20. The bolt pattern you are looking at is for a Corvette but I believe it may not fit the Camaro also. No promises though.
Sent from my SM-T377T using Tapatalk
2011 Summit White Synergy Series Edition, the hot innocent woman named Ava that we show off around town, dressed in white complete with angel's wings. Sold, but never forgotten.
2014 1SS 1LE. Bama, sporting Red Rock Metallic demon's horns, when we are ready to get naughty and open a can of whoopass! Airaid, Spectre, Xpel,Bowler shifter Peddars, UMI, Ult Perf. Diode Dynamics, JRE Tune, XS Power battery,
Hooker Headers Blackheart exhaust,Powerbrake
InstaGram & Twitter: @jlouie62
FB: hangtimeracing
jksynergy is offline   Reply With Quote
Old 09-15-2020, 05:37 AM   #10
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
Originally Posted by Athletics101 View Post
Absolutely.
Do not use 5x120.65mm bolt circle wheels on a 5th gen Camaro. You will stress the studs and not tighten the wheel correctly. Correct bolt circle is 5x120mm. 5x120.65mm bolt circle is the old small Chevy 4.75x5 bolt circle.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers, rotors & pads, BMR Trailing & Toe Arms, rear cradle & diff bushes, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, GTO clutch reservoir, LS9 cam, Comp valve springs, Melling 10296 oil pump, CR5 timing chain, LS6 damper, CAI Cold Air Intake, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 whls, 275/40/20 & 315/35/20 tires, 2011 Convertible spoiler, 1LE front spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, wrapped console & Grant steering wheel.
flht99b is offline   Reply With Quote
Old 09-15-2020, 06:03 AM   #11
Deputy347k9
Deputy347k9's Avatar
Drives: 2014 Ashen Gray Convertible
Choose Chevrolet Camaro model with 5X120.65 PCD
Chevrolet Camaro models that are suitable for a 5X120.65 bolt pattern.
Search by Chevrolet Camaro modification
search
Camaro 3.8 IV Restyling (1998-2002)
Camaro 5.7 IV Restyling (1998-2002)
Camaro 5.7 SS IV Restyling (1998-2002)
Camaro 3.4 IV (1993-1995)
Camaro 5.7 IV (1993-1997)
Camaro 3.8 IV (1995-1997)
Camaro 5.7 SS IV (1996-1997)
Camaro All trims III (1982-1992)
Camaro All trims II (1970-1981)
Camaro All trims I (1967-1969)
This spacing will fit many other Chevrolet models, however all are early models, some going back to 1955!
As just previously stated, "stay away from them unless you want trouble", they might go on but they might also cause serious and dangerous damage.
Deputy347k9 is offline   Reply With Quote
Old 09-15-2020, 07:18 AM   #12
SSammy
SSammy's Avatar
Drives: 2015 2SS A6 Commemorative Edition
Mine are 20x10 +35 MRR228 with 275/40zr20 all 4 corners. Originally installed at stock height and now on 1” BMR drop springs. No problems or rubbing either way.
SSammy is offline   Reply With Quote
Old 09-15-2020, 10:27 AM   #13
Avenging Orange
Avenging Orange's Avatar
The offsets are correct for stock stagger. +35 rear and +23 front for a 10" wheel....which should put them flush.
I have 20x9 square at +30 and added 5mm spacer to the fronts to get them to a +25. Both fit perfectly flush with the fender. If you are still confused, call one of our wheel sponsors. I talked at length with Akio @ PK Auto Design, he really helped me understand offsets and back spacing and how it applied to different wheel widths.
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
