08-01-2020, 05:27 PM | #1 |
Drives: 2017 Silver SS Convertible Join Date: Dec 2018
Only Manual Of Top Possible
Hey I have a 2017 Convertible camaro and I been getting the message “only manual operation of top possible”. Do y’all know the cause or the fix for this? The top won’t go down at all.
08-02-2020, 11:35 AM | #2 |
Hot Camaro
Might be helpful if you could post any details of any troubleshooting you've already done, when it occurred, what else might have been going on leading up to that time, etc.
First thing that comes to mind is to check the trunk partition and make sure it's attached in place correctly then verify that the trunk is closed and the car doesn't think it's open. |
08-02-2020, 11:39 AM | #3 | |
Hey I double checked the partition divider and it’s in the correct position. Usually when it’s not in the right area I get a different error code on the screen. Now it’s just saying “only manual of top possible” when I click the convertible button either direction. I also noticed when I try to pop the truck now it says “top not secure” put it won’t let me secure the top. I’m confused on what made it start doing that
08-02-2020, 11:45 AM | #4 | |
Hot Camaro
Otherwise, sounds like a trip to the dealer to at least read the specific code that it's throwing is in order. |
08-02-2020, 11:47 AM | #5 | |
Yup I’m going to play around with again today. Thank god the top is in the almost closed position and not stuck wayyyy back in the trunk lol
08-02-2020, 12:26 PM | #6 |
Thank you Al Oppenheiser!
Disconnect the negative battery terminal for 20+ mins. No guarantees but worth a shot.
08-02-2020, 01:47 PM | #7 |
08-02-2020, 02:46 PM | #8 |
Drives: '17 2SS convertible'20 Yukon Denali Join Date: Nov 2011
Had that problem when I replaced the battery. There is a top position sensor behind the battery on part of the top mechanism. The plug is easily knocked off the sensor when you are putting a new battery. I did that last year. :(
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers Delivered: 08/15/2016 #TeamBeckyD |
08-02-2020, 02:52 PM | #9 |
Is it like a plug and play sensor and is it easily reached?
08-02-2020, 04:13 PM | #10 |
Drives: 2017 ZL1 Convertible A10 Join Date: Aug 2017
I know you looked, and that usually you get a different code, but have you tried removing the partition divider, and replacing it again. worth a try
'17 White ZL1 A10 Convertible - TM ported TB - RotoFab CAI - 2.3" griptech upper pulley - Kooks 1 7/8" Headers with High Flow Cats - Borla S-type Catback - Audio Overhaul - NavTV M650-GM - 20" BlackDiForza- Michelin Pilot Sport4S - Tuned at BRC Raceworks (606rwhp/675trq)
'14 CTS-V Coupe - ZL1 lid - Ported TB - Ported Snout - AirRad CAI - 8.66" lower - 2.55" upper- Greenbelt - SW Headers - SW Catback - Varimax Intercooler Pump - Track Attack Intercooler-Tuned at BRC Raceworks (551rwhp/516trq) '17 Maserati Levante- STOCK |
08-02-2020, 10:29 PM | #11 |
It's behind the battery. I ended up taking it to the dealer before I learned about the sensor.
Richard
08-03-2020, 07:59 AM | #12 |
Hot Camaro
08-03-2020, 08:32 AM | #13 |
Drives: Camaro 1SS A8 Vert Join Date: Sep 2018
Right above the battery , with 2 yellow wires.
It would be right behind the tail light.... |
08-03-2020, 01:49 PM | #14 |
Yeah, between the battery and the fender, I think.
Richard
