07-20-2020, 05:47 PM | #1 |
PushRodLT1
Drives: M1SS1LE Join Date: Jul 2016
Drops of Oil
I am seeing a few drops of Oil every now and then on my garage floor,
The SS 1LE is almost new, had purchased it at 2250 miles and since have driven only about 400 miles. Any thoughts on why this might be happening? Thanks.
2SS Black, M6, NPP, MRC
Mods: Borla ATAK Axleback w/NPP, Roto-Fab CAI, RPI Designs Splitter, ACS Spoiler, Michelin PS4S Tires. |
07-20-2020, 05:49 PM | #2 |
Oil changed recently? Could be residual oil that got onto the undercarriage when the filter was removed.
07-20-2020, 05:49 PM | #3 |
Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
Check your oil pan bolts, not sure if you have a 19 but my 17 came from the factory with loose oil pan bolts. I forgot the torque on them but there are threads on here about it.
07-20-2020, 05:50 PM | #4 |
Drives: 2016 Camaro 1LT Join Date: Jan 2016
i dont think without any info on where you're seeing the oil under your car falling from ...like a picture of the area of the car directly above the pools...nobody is going to be able to tell you anything.
Obviously it's not normal, so .... |
07-20-2020, 05:51 PM | #5 |
PushRodLT1
Yes, the dealer had changed oil prior to the sale.
07-20-2020, 07:04 PM | #6 |
I’d get under there if possible and wipe down the underside. Get as much oil wiped up as you can see. Check that the filter is tight (just turn by hand). Also check the oil drain plug is tight. Recheck in a few days to see if you can spot where the oil is coming from if it continues leaking.
07-20-2020, 07:12 PM | #7 | |
https://www.camaro6.com/forums/showthread.php?t=567130
Originally Posted by arpad_m - “Aww, yet another oil thread with almost the same question in the OP“ |
07-21-2020, 06:53 AM | #8 |
Mine turned out to be a bad oil pan gasket and was replaced under my powertrain warranty.
07-21-2020, 08:47 AM | #9 |
Drives: 2018 ZL1 Camaro 6M Red Hot Join Date: Aug 2013
I had the exact same issue after the dealer changed the oil in my ZL1. Turned out to be the oil filter.
It was so loose, I had to turn it one complete revolution to get it tight. Check your filter.
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
07-21-2020, 11:30 AM | #10 |
Drives: 2021 300 Join Date: Jan 2015
Take it back to the dealer and let them check it. so there is a record of it.
07-21-2020, 12:12 PM | #11 |
376 cubic inches of fun
When the filter is loose, oil collects on the underside of the filter. When the drain plug is loose, oil collects on the underside of the drain plug.
It's great to get sight unseen opinions here in the forum, but nothing beats getting under the car as a first step. |
07-21-2020, 02:11 PM | #12 |
Drives: 2019 ZL-1 Join Date: Feb 2009
I had a Wix oil filter develop a pinhole leak......ugh
2019 ZL-1 Acquired 4/23/21 at 6300 miles. Riverside Blue, A10, PDR. Traded in 2017 2SS with 6M and 32k miles. Continental Extreme Contact Sports. Now has 10,000 miles...
2012 Yukon XL Denali w/ 6.2 AWD |
07-21-2020, 05:31 PM | #13 |
I agree with Jeb114! Run it back to the dealer and let them check it out.
07-22-2020, 07:17 AM | #14 |
So, it has been 2 days and the OP still hasn't checked under his car?
Man, when I found oil on my driveway, I was under it in a matter of hours...
