07-10-2020, 08:13 AM | #1 |
Drives: 2015 Black rs/ss/1le Join Date: Apr 2018
Z28 sway bar (kit) install question
Hi.
I’m in the process of installing the front sway bar. The sway bar came with the links installed. How do I get it off without damaging the boot? There’s witness paint so I’m sure it’s torqued to spec. There’s no way to snake this in there with the links attached is there? The rear sway bar is the same. Thanks! Edit: I’m so embarrassed. It was staring at me right in the face. The top of the stud has a hex on it. Sometimes you can’t see the forest through the trees. Last edited by Level300; 07-10-2020 at 10:05 AM. |
