07-06-2020, 10:08 AM | #1 |
Drives: 2017 Focus RS Join Date: Nov 2017
SOLD: 2014 Camaro Z/28 Red A/C&Stereo
SOLD to a person from Alabama, new owner of Red Z/28 #402
Everyone, I'm at that time where I'm strongly debating (and 70% of me convinced to) sell the Z/28. Why? Partly because I just don't get to drive it anymore and partly because I purchased a cheaper toy that I am more like to actually take the track like I had intended for this. Please excuse the water spots/drops in the pictures, I was in a rush to get photos before I had to head to an appointment and didn't dry the car thoroughly after washing. So the major details, 2014 AC and Stereo. 14425 miles (will go up but its not a daily driver). Everything is stock unless mentioned. Red Shiftknob, still have stock unit. Exhaust flap controller switch which can be removed in <5 minutes ARH 1 7/8 headers, car comes with stock manifolds as well. Cammotion Cam. Also includes stock cam. BTR Valve Springs w/ Titanium Retainers Morel Lifters Hardened (and shorter Pushrods), 0.135" side wall, running 0.063" preload (Morel recommends .060-0.075) Powerbond SFI rated Balancer (stock unit was de-laminating) ARP fasteners (head bolts, cam bolts, crank bolt) TR7IX spark plugs Head/Valve work done by AHP with MS90 Valve Guides, Ferrea exhaust valves, valve job, milled 0.030 for compression, tuned on 93. GMax RS Tires ~2000 miles or so Car is available for PPIs, dyno tests, etc. Let me know. Videos https://www.youtube.com/channel/UChQ...-Hc1vomvdb5csg Let me know if you have any questions. Last edited by DasBaldDog; 07-24-2020 at 02:03 PM. |
07-06-2020, 10:32 AM | #2 |
Drives: 2010 IBM 1SS (Former) Join Date: Feb 2009
What's your asking price? Not sure I see it above. Thanks.
07-06-2020, 10:41 AM | #3 |
07-06-2020, 06:16 PM | #4 |
Drives: 2018 ZLE (M6/hyper blue) Join Date: Nov 2015
I've been watching yours on fb marketplace since before you started posting elsewhere. I considered yours, strongly...if I wasn't set on getting stock, you would've gotten a call from me. Hell, you still might.
07-07-2020, 03:07 AM | #5 | |
I would say that it could be taken back to stockish. Due to the milled heads, you'd need atleast SOME cam in it to keep the dynamic compression down but I think there are a ton of sleeper/stealth cams that would keep it more than happy. That, swap out the headers (sell them on here), I'd keep the shift knob I put on there but if you want stock I still have it... and voila... stock (ish). But I get your goal, friend. Let me know if you have any questions I can answer or any thoughts worth kicking around. |
07-08-2020, 10:37 AM | #6 | |
If what I have in mind falls through (but its looking really solid at this point), then I'll hit you up. Doubt you'll have it still by then though since you're giving a good deal on it. |
07-08-2020, 01:53 PM | #7 | |
BUT..... I like money too, so I'm torn. Just let me know, friend. |
07-13-2020, 01:10 PM | #8 |
Updated some details (mainly some upgraded/aftermarket parts using re-build of top end).
07-17-2020, 11:33 AM | #9 |
Drives: 14 1le Join Date: May 2012
Car sounds good. Who tuned it and do you have any dyno numbers?
06 gto Maggie 489 rwhp sold
05 gto ERL/HKE 454 609rwhp na sold 06 Z06 500 rwhp sold 10 2ss ERL 427 530 rwhp sold 14 1ss 1le |
07-17-2020, 01:22 PM | #10 |
Drives: 2006 BOM GTO Join Date: Jul 2018
15 1lE and some cash??
07-18-2020, 04:13 AM | #11 |
07-18-2020, 04:15 AM | #12 | |
SpartanLSX tuned the car (they seem to do a fair number of LS7's in the area), they did the tune after the head/header/cam install, and recommended that I change to the colder plugs (which I had in my mind to do already) and then spiffied up the tune after I put the new plugs in (he said they got a few more degrees of timing without tickling the KR) No dyno numbers but similar setups without the milled heads do 550-560 wheel, so I'd guess another 10-15 with the milled heads. If you are interested and want a dyno as part of a PPI, I will make the car available to any accredited/capable shop. |
07-24-2020, 09:58 AM | #13 |
Sale Pending. Will update as Sold/Not Sold later.
