06-14-2020, 10:28 PM | #1 |
Drives: 69 Z28 RS 19 2SS Convertible 10 Ava Join Date: Jun 2020
Engine cover paint burn off
Hey all, new here and have a question. The CAMARO on the engine cover is burning off. The paint is flaking off. Left side more so then the right. Any fixes recommended? Thanks
06-14-2020, 11:13 PM | #2 |
Drives: 2018 Camaro SS 1LE Join Date: Jul 2018
Mine is all gone too...Camaro has got some 'heat' under the hood! ;-)
06-14-2020, 11:45 PM | #3 |
Eventually they all flake off. Some guys here redid the letters with heat resistant paint. Alternatively, I still have my stockers, you can take them off my hands (and with them buy a little more time, heh).
06-15-2020, 07:03 AM | #4 |
Drives: 2018 ABM 1SS 6M Join Date: Jan 2020
Mine are doing the same thing. I’m having them replaced under warranty at my dealership.
2018 1SS 6M ABM
06-15-2020, 07:16 AM | #5 |
Drives: 2019 Chevrolet Camaro 2SS Join Date: Jul 2019
My car is silver and black, so when mine started coming off I just removed the rest of the paint with brake clean I like the look as those letters was the only thing that was red on the car
06-15-2020, 09:16 AM | #6 |
Drives: 2017 Silverado/2017 ZL1 Join Date: Aug 2019
i just painted mine with some high temp paint
06-15-2020, 09:39 AM | #7 |
Drives: SS A8, NPP, Red Hot Join Date: Jan 2019
Ditto, mine is flaking off at 19,000 miles. I'll just repaint with high temp paint like everyone else.
06-15-2020, 03:57 PM | #8 |
Drives: 2016 Camaro SS Convertible Join Date: Aug 2016
It happened to my and the dealer replaced them under the bumper to bumper warranty.
06-16-2020, 07:37 AM | #9 |
Rather than deal with the factory paint that tends to flake - I decided to add some colors of my choice with all the engine covers. All the paints used can withstand the high under hood temps.
2010 Camaro 2SS Cam/Headers/CAI/3.91 gears 476 rwhp/440 rwtq (sold) |
06-17-2020, 01:02 PM | #10 |
Drives: 2017 2SS / 2003 S10 Crew Cab Join Date: Oct 2019
another option is replacement vinyl lettering...I bought these in red: https://www.ebay.com/itm/222592198990
Never say never! |
06-17-2020, 06:54 PM | #11 |
Perfect. Thanks all!
07-14-2020, 10:11 AM | #12 |
Drives: 2016 Summit White Camaro SS Join Date: Jul 2018
Chevy will replace at no cost if car is still under 3 years / 36,000 miles
09-11-2020, 12:17 AM | #13 | |
Drives: '19 Camaro M1SS1LE Join Date: Aug 2020
09-11-2020, 01:16 PM | #14 |
What paint did you use (high temp, but what brand)? A: I used the spray paint in the attached photo to paint the silver/gray parts. I had River City Creations (currently not in business) paint the blue parts and Camaro letters. They used Hyper Blue auto paint. How'd you do it? A: All the silver/gray parts I painted myself using the rattle can. I cleaned all parts using rubbing alcohol and then sprayed 3 coats Did you use clear coat over it? A: No I guess that cover just pulls straight up off the engine? A: The blue parts pop right off. The center silver part requires removal of the studs that hold the blue parts on and cutting some zip ties (no need to replace the zip ties - they were factory overkill as the wire bundles held by the zip ties are not going anywhere). The silver/gray lower parts (ignition coil covers that look kinda like valve covers) were the hardest. They require a Torx #10 bit and some patience to get on and off.
