Old 12-20-2009, 05:44 AM   #1
AdnanHfuda
AdnanHfuda's Avatar
Drives: none :(
ATV problem, engine/carburator experts help!!
i took out my ATV that has been sitting for a couple of months now after changing the spark plug. problem is the engine doesnt feel as strong as it used to, i cant drift or do doughnuts on sand anymore. when i push the throttle to 100% the thing slows down rather then speed up.. plus when i filled it up with gas it leaked out of the carburator for a while but then stopped for no apparent reason.
AdnanHfuda is offline   Reply With Quote
Old 12-20-2009, 11:59 AM   #2
Black5thgen
Drives: 2007 C6
Best thing to do is pull off the carb, take out the low and high speed needles and spray them and the carb liberally with carb cleaner. maybe even soak all the parts in carb cleaner. You will be amazed at all the sediment that comes out of the float bowl.
Black5thgen is offline   Reply With Quote
Old 12-20-2009, 12:05 PM   #3
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
Use a strand from a wire brush to clean out any small orifices you can find in the carburetor.
BMR, CAI, DynoMax, Elite Eng., Hurst, Jannetty, Clear Image Headers & Hi Flow cats, Jet Hot, LSR, TSW, VMax, Vredestein
PAUL SS is offline   Reply With Quote
Old 12-20-2009, 09:18 PM   #4
ls7camaro
Drives: 2010 camaro
I agree, sounds like you need to clean the carb
ls7camaro is offline   Reply With Quote
Old 12-21-2009, 03:45 AM   #5
AdnanHfuda
AdnanHfuda's Avatar
Drives: none :(
ill open it up and clean it but i dont know what you mean by carb cleaner? can i buy it at a repair shop or where?
Old 12-21-2009, 05:23 AM   #6
AdnanHfuda
AdnanHfuda's Avatar
Drives: none :(
cleaned the carburater on the inside with petrol and q-tips and still doing the same thing. any other ideas?
Old 12-21-2009, 06:57 AM   #7
AlSuwaidi
AlSuwaidi's Avatar
Drives: BLACK LS3 GCC-Spec
Make sure all the small openings and passages are clear, check all lines/pipes coming in and out of carb for blockage, check to see if jets/needles are blocked.
AlSuwaidi is offline   Reply With Quote
Old 12-21-2009, 07:11 AM   #8
Camarorss350
camaro blogger
Camarorss350's Avatar
Drives: 2010 Black on Black SS/RS
Send a message via AIM to Camarorss350
sounds more like a spark issue than a air/fuel problem...
Camarorss350 is offline   Reply With Quote
Old 12-21-2009, 09:39 AM   #9
Skyblu
Skyblu's Avatar
Drives: 2010 Aqua blue 2SS/RS M6
well I know all this new gas with ethanol reeks havoc with small engines with carbs, ours did the same thing afeter letting it sit for a few months, as every one has said we took the carb off soaked in carb cleaner, got new gasket changed spark plug and some fuel line worked fine after. Don't know what else to tell you to do if that doesn't work.
Skyblu is offline   Reply With Quote
Old 12-21-2009, 04:52 PM   #10
SleepWarz
Drives: 1991 New Yorker, 69 Tbird, ABM2SSRS
Maybe your clutch cable is a bit streched too... letting it slip....
SleepWarz is offline   Reply With Quote
Old 12-22-2009, 01:27 PM   #11
AdnanHfuda
AdnanHfuda's Avatar
Drives: none :(
very little idea of what happened but its working now . i think cleaning the carburator did it along with pumping up the tires to full. pumped them up after getting a flat then driving it down a closed highway i noticed its working properly again thanks for the help
Old 12-22-2009, 01:55 PM   #12
Chrisrp454
Chrisrp454's Avatar
Drives: 2010 ABM 2SS/RS M6, 98Z28 M6
Was it setting with ethanol gas in it? If so thats probably the issue.
Always Remember! Rest in Peace Brothers
9/11/2001. And thanks to all those who defend and serve!
Ordered 5/23/2009
3400 with TPW of 08/03/09
3800 8/11/2009
Arrived 8/21/2009 2SS/RS/Aqua Blue/Grey Interior
Chrisrp454 is offline   Reply With Quote
Old 12-22-2009, 06:59 PM   #13
Iroczlover
The Krazzy bytch
carb cleaner go to any auto shop should be the same stuff, You know carb cleaner stuff you spray in the older cars with Carbs lol.
Mine does something like that, but after it warms up it dies, when I start it I have to have the choke out then as it warms up you put the choke in, but it will only go half way or it will die.
Trying to sell my daughters old one that way I can take mine in the shop. lol.
GM Bulletin HVAC system reprogram caused window problem VegasSS Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 6 10-09-2009 09:05 AM
first problem with Camaro RobH Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 6 10-05-2009 09:17 PM
GM Bulletin HVAC system reprogram caused window problem VegasSS 5th Gen Camaro SS LS LT General Discussions 16 10-02-2009 02:10 PM
pm problem drivingincamaro Site Related Announcements / Suggestions / Feedback / Questions 4 06-23-2009 10:20 PM
Somewhat Annoying Back Seat Problem! ZNOLMT 5th Gen Camaro SS LS LT General Discussions 5 06-21-2009 09:22 AM
