03-12-2020, 05:39 PM | #1 |
Livin' the Dream
Drives: '23 Charger GT, '23 Stingray Join Date: Mar 2013
2019 Camaro Reverse Lights
I went cover to cover in my owner's manual, Googled, and even called the parts department at the dealership(I have a GM part number, but no other number) and no one can tell me what the replacement bulb is for the reverse lights on my 2019 Camaro. Can anyone help me out? Thank you in advance.
I plan on switching to LED's and hopefully Diode Dynamics has a set that doesn't require a special harness. Chevy dropped the ball on the marker lights(again) and the reverse lights(again). LED's last longer, provide better light, and look cooler.
If you spell Chuck Norris in Scrabble, you win. Forever. |
03-13-2020, 08:03 AM | #2 |
I used these on my 2019 Camaro SS, they work perfectly.
https://store.ijdmtoy.com/products/l...-20-001a-white
2020 Range Rover Sport HSE P525 Supercharged 5.0 - Firenze Red - 9012 wheels
SOLD 2019 Camaro SS -Wrapped in Matte Magnectic Black - Anderson Carbon Hood and Rear Spoiler – Ikon front spoiler – OEM ZL1 Side Rockers - ZL1 Addons Diffuser - BMR 1.0” Lowering Springs - MRR 228 Wheels 20x10 and 20x11 RIP 2016 Camaro SS https://www.camaro6.com/forums/showthread.php?t=565453 SOLD 2010 Camaro SS Featured in GM High Tech Performance and Camaro Now Magazines - http://www.superchevy.com/features/g...of-perfection/ |
03-13-2020, 08:35 AM | #3 |
I was going to do the harness till I realized on the '19 and '20 models the bumper has to come off to remove the tail light housing. I just did the resistor and gen5diy bulbs and that worked great.
03-13-2020, 09:51 AM | #4 |
Livin' the Dream
Thanks you guys!
03-17-2020, 11:30 AM | #5 |
I installed mine without removing the rear bumper.
03-17-2020, 12:07 PM | #6 |
03-18-2020, 11:26 AM | #7 |
exactly.
03-29-2020, 04:04 PM | #8 |
Drives: 2020 Zl1 A10 Riverside Blue Join Date: Mar 2020
I'm trying to find led reverse light for my 20 zl1 but I cant seem to find any. I have heard of issues people have replacing the bulbs. What is the best route to take without having issues?
10-13-2020, 11:56 PM | #9 |
Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
Thread bump. I thought I'd just settle with halogen bulbs, until I visited a friend's place last night and I couldn't see anything that's not lit up by the LED license plate lights. So yeah, I ordered a pair of VLED HO6, and this is something I would have to deal with when they arrive.
I will try to attach small resistors first, but in case that doesn't work, I will grab the harness. How did you go about doing that? I took a few pics under the bumper today and it looks like you may be able to reach the connector by jacking the car up and reaching it from below the car. Not 100% sure if this would work, though.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
10-15-2020, 05:54 AM | #10 | ||
Tampa Bay Camaros
Drives: 2017 Krypton Green 2SS Join Date: Jul 2011
With the ijdmtoy kit mentioned above, each bulb has its own harness and resistor. No need to remove the bumper. Simply change the bulb and attach resistor as shown on these pics.
Me and wife, in order
2011 2SS SGM 2013 2SS Hot wheels vert 2016 C7 DSOM 2012 2SS yellow vert 2017 2LT Krypton Green 2018 2LT Hot wheels crush 2020 2SS Shock vert. 2017 2SS Krypton Green coupe |
10-15-2020, 09:21 AM | #11 |
I did the Gen5DIY harness on my 19Z for the LED’s and it can in fact be done without removing the bumper. I was able to slide my arm up into the bumper cavity from the diffuser and disconnect the harness mostly by feel. It can be a pain to disconnect but once you do it’s a simple plug and play! I’d take note that those resistors had a lot of room to bounce so I zip tied them to the harness to limit that, but it is possible with some patience and nimble hands
Morimoto Headlights, AWE Touring Catback, MM Catch Can, ADM V2 Reservoir, Roto-Fab, C&R Oil Cooler, 1LE Grills
10-15-2020, 02:36 PM | #12 | ||
Current:
10-16-2020, 10:36 PM | #13 |
Welp, got it working with a 200 ohm resistor. No glow and reverse cam shuts off properly. Only installed it on the driver side LED.
I will probably get a higher wattage resistor. I used a 1/4 W resistor which is below the wattage it will see during usage. P=V^2/R, so (14 V)^2/200 ohm=0.9ish W. It worked okay in the short durations I left my reverse on, but in the long run, I will get and solder a 1 W resistor on just to be safe.
Current:
10-19-2020, 10:59 PM | #14 |
Quick snip of the backup lights at the gas station.
So much better now. Sent from toaster or something
Current:
