03-12-2020, 06:26 AM | #1 |
Radiator separated
Has anyone ever seen our radiators leak from the plastic end tanks?
I noticed some water/coolant on my garage floor and after investigating, it's coming from the bottom of the radiator where the plastic end cap meets the aluminum core. If I squeeze the plastic end cap, the leak gets worse. What a piece of shit. I have had zero cooling issues. I have a centri blower with surprisingly low IAT's, and my water temp is always around 180ish in Florida. I have no need to upgrade the radiator for cooling purposes, especially since it's a very tight fit already, but I'm afraid to put another dual material radiator in and have the same problem later. This car will see a bit more boost... What are some cost effective options for replacements? I'd rather try another stocker before I drop $799 on a dewitts or becool, so dont bother suggesting those high dollar deals that need fans and wont fit. I need a solid aluminum "drop in replacement" that wont break the bank. Any suggestions?
2011 Camaro SS---SOLD
03-12-2020, 06:29 AM | #2 |
The leak is Right where the metal teeth grab the plastic end tank.
03-12-2020, 08:42 AM | #3 |
There’s someone selling a mishimoto radiator with spaal fans/fan shroud on it for cheap in the classified
2010 2SS/RS
03-12-2020, 09:38 AM | #4 |
Is divorce next or marriage counseling?
03-12-2020, 10:02 AM | #5 | |
I think counseling at a minimum when she realizes the "engine" I just bought doesnt even have heads. hahaah Still got another $4000 to complete the longblock. Which I just sent to the Home Depot card to close out. So that bought me some wiggle room.
03-12-2020, 11:32 AM | #6 |
I have a similar issue, mine is weeping from the crimps. I looked into Mishimoto, which is still too high for me right now. Next option was Champion radiators on Ebay. They have decent reviews from what I can find and are supposedly 'direct fit' in 3 and 4 row for our cars, all aluminum.
They range from $205-300. https://www.ebay.com/itm/3-Row-Alumi...8AAOSwDlda5z5M
03-12-2020, 11:46 AM | #7 |
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
I-800 radiator ,inexpensive and made in China but works as good as the factory radiator . Has a Lifetime warrantee. Under $150.00. Been using them on lot cars and trucks with no problems. The one we put in my brothers 2005 f150 5 years ago and 200000 miles ago is still working fine in the Phoenix heat ,and he tows a 27 ft boat up to lake Powell twice a month in the summer every year. Should work fine in a stock or lightly modified Camaro. How it would work with FI I don't know , but if the factory radiator worked b4 it leaked this one should be as good.
OLD GUY FLYING FAST AND LOW
03-12-2020, 12:04 PM | #8 | ||
Just searched for I-800 radiators, but didnt find much. I'd prefer direct fit. Also found a remanufactured unit from Sunbelt (local) on ebay for $83 shipped, lifetime warranty. Sounds like a winner for the quick fix
03-12-2020, 12:12 PM | #9 | |
Thanks
03-12-2020, 03:40 PM | #10 |
376 cubic inches of fun
Years ago when plastic tanks with crimped on aluminum cores were a new thing, radiator sealant tabs were called out in GM shop manuals, to be added with every coolant change.
I would try that. |
03-12-2020, 05:47 PM | #11 | |
I thank you very much for your suggestion, but I think I'm just gonna get one that doesn't leak. Good info tho. I'd do it if it wasn't a high powered deal.
03-12-2020, 11:33 PM | #12 |
Drives: 2010 1SS LS3 Join Date: Aug 2019
Don’t put anything in the coolant! Just...no! Go with a known brand that works. You have too much invested for a stock replacement. Go bigger and move some things around to make it fit. You may have pushed some combustion gas into the coolant(lifted a head) and pressurized the cooling system. Happens when you send that much boost through with stock head bolts. Just a thought. Plastic radiator tanks will leak when pushed past the pressure on the radiator cap. Happens all the time on production oem cars, trucks, and equipment.
2010 CGM 1SS
408/4L80E/ZL1 ESS G4 |
03-13-2020, 11:41 AM | #13 |
Radiator 103672
IN STOCK $155.38* ADD TO CART OR CALL FOR ASSISTANCE 1-800-381-3688 *DETAILS: We recommend you talk to our parts expert to help you decide if this is the right product for you. You may have issues with fit on this radiator if you don't pick the right one. We are open 19 hours a day to serve you, just give us a call! PRODUCT DETAILS Part Number: Warranty: 103672 Limited Lifetime
03-13-2020, 01:31 PM | #14 |
15 Year LS1Tech Member
Drives: 2010 ss 391ci LS3 Join Date: Apr 2017
Same thing happened to mine. Picked up an amazon one for $110 (they're $152 now) and it's been just fine for over a year. No issues in any conditions, just like OEM.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
GJDM |
