03-10-2020, 10:36 AM | #1 |
Drives: The DSSV Twins: ZR2 and ZLE A10 Join Date: Oct 2019
PTM and recovering from too much lift mid turn
Hey track rats,
Does anyone know for a fact if PTM can save you mid turn if you lift too much? The scenario is I'm used to lifting on purpose in tight, slow corners (mainly autocross when I do this) to help the rear end kick around, but when tires are too cold or traction has changed, e.g. gravel, tire marbles, etc., it can change the amount and speed I should have lifted and I just spin out. My natural reaction is to just apply the brakes and ride it to a stop. I'm completely new to PTM, but is it the case that if I floor it, PTM will kick in and maximize my traction during the slide? Too scared to try this until I do another autocross with a safe section to test. Any other non intuitive tricks you can share about using PTM? |
03-10-2020, 10:51 AM | #2 |
1LE Convert
Drives: 2018 ZLE Join Date: Apr 2017
PTM can't help you with over rotation from a lift. ESC can though.
I think you are generally right that squeezing a little bit of throttle to settle the rear is the right thing to do unless you already got the car to snap.
2016 Porsche 911 GTS (Racing Yellow)
2002 BMW Spec E46 race car (Lizard Green) Previous cars: - 2018 Camaro ZL1 1LE (Red Hot) - 2018 Miata RF GT (Machine Gray/Auburn) - 2017 Camaro 1SS 1LE (Summit White) - 2008 BMW 135i (Montego Blue) - 1996 BMW 328i (Arctic Silver) |
03-10-2020, 06:29 PM | #3 | |
03-10-2020, 06:48 PM | #4 | |
03-10-2020, 08:26 PM | #5 |
Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
PTM is limited to available tire traction. PTM works best when throttling out of a corner where the e-diff. also comes into play.
I have gotten a decent (maybe 30 degree) slide even in Dry mode with worn rear tires while lifting in a 70 MPH sweeper. I have noticed that assuming you start with all 4 fresh tires, the car is very neutral and then as the tires wear, you will get more oversteer tendencies, at least with how my tires wear on the street. My wear rate is about 2:1 front to rear with my driving style. Fresh tires I use Sport 1, after about 75% rear tires gone, I keep it in set to Dry mode.
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
03-10-2020, 10:33 PM | #6 |
Drives: 2012 BMW 135i Join Date: Nov 2016
Sorry guys - I may have my facts wrong but:
PTM Wet - SC/TC active PTM Normal - SC/TC active PTM Sport 1 - TC / SC on; less intrusive then normal PTM Sport 2 - I thought SC was still on but correct me here PTM Race - Optimal warm tire on throttle help; zero off throttle help - you break it you fix it. What OP is looking for is "Comp Mode" - the car needs to be in "Sport Mode" (not "Track Mode"); two quick presses of the traction control button and "Competition Mode" should flash on the dash screen. Competition mode allegedly does not have TC (i don't think that's true from my experience) but absolutely has on and off throttle SC enabled. It's a very interesting mode and most certainly collects the car quicker then you can. Feel free to correct as appropriate I did this from memory. |
03-10-2020, 10:54 PM | #7 | |
03-10-2020, 11:52 PM | #8 |
NOXQCES ZL1
Drives: 2017 Camaro ZL1 Join Date: Mar 2019
Doesn’t matter what mode you’re in..... lifting mid-corner, especially over a crest will get you in trouble. Traction and stability control are only effective with good traction. Get the car light or too far out and all bets are off.
03-11-2020, 12:06 AM | #9 | |
03-11-2020, 05:53 AM | #10 | |
03-11-2020, 07:36 AM | #11 |
This is all great, guys. Any more PTM tips and tricks?
03-11-2020, 12:46 PM | #12 |
Drives: 2016 Challenger Hellcat, 2018 ZL1LE Join Date: Dec 2009
those cold 3R tires are what got me into trouble 2 weeks after buying my first ZL1 1LE, I ended up wrecking into the guardrail just by merging onto the highway at normal speeds.
when you guys say "lift" mid corner you mean gassing it to get the back to kick out correct?
2016 Challenger Hellcat /B5 blue/Sepia interior/Brass Monkey Wheels/
2018 ZL1 1LE/Red hot 2019 Shellby GT 350R/ Oxford white/ Matte Black Stripes/ Carbon Fiber Dash/ Electronics Package #413 |
03-11-2020, 01:09 PM | #13 | |
Man, so sorry to hear about that guardrail! Hope you get that beauty back good as new soon. |
03-11-2020, 02:14 PM | #14 |
Drives: 2019 ZL1 Crush Join Date: Jan 2019
Search for lift off oversteer on the google. It is a weight transfer thing, not much can help from an electronics side as you no longer have the needed traction
2019 Crush A10
E-Force 2650 670WHP 615WTQ All besides the 2650 is bone stock down to the air filter. |
