02-28-2020, 12:48 PM | #1 |
Onyx_Z7 <— Instagram
Drives: 2013 2ss 1le Join Date: Aug 2014
Problem after problem
I just can’t catch a break with this car smh. Okay so after I put my stock steering wheel back on I got a service power steering/service stabilitrak message. The car would run fine but I have 3 of the stabilitrak lights on and anytime I punch the gas from low rpm I get a reduce engine power and check engine light. Went to get a code read and came back with a P0606 which is and ECM/PCM related code. I disconnected the battery for two hours and all was fine until I mashed the throttle. would me changing out the steering wheel throw off something making my car act this way?
02-28-2020, 01:02 PM | #2 |
Shouldn't have. How old is your battery? These cars are very sensitive to batteries on their way out and will throw all sorts of weird codes. p0606 can be caused by a momentary loss of power to the ECM. Did you disconnect the battery before swapping over the steering wheel? I would start by charging fully, or replacing the battery resetting the codes with a scan tool. If that DTC returns it is essentially a death sentence for the ECM
02-28-2020, 01:19 PM | #3 | |
02-28-2020, 01:30 PM | #4 |
15 Year LS1Tech Member
Drives: 2010 ss 391ci LS3 Join Date: Apr 2017
Did you lock the steering shaft when removing/installing? Any airbag light? Did you check the clocking spring? Any loose grounds?
GJDM |
02-28-2020, 01:56 PM | #5 |
The clock spring has to be perfectly aligned when you remove and replace that wheel. There is a window on the clock spring that helps with alignment.
If steering angle doesn't match what the clock spring reports you will get a ton of errors.
02-28-2020, 02:33 PM | #6 |
Here is its current position steering wheel is upside down btw
02-28-2020, 03:51 PM | #7 |
FIXED haha I’m a dummy lol found out that the yellow clock spring window needs to be by the 5’ o clock position for it to be aligned did that and no more service stabilitrak or power steering lights!
02-28-2020, 07:21 PM | #8 |
Glad you found it. I shouldn't have assumed you put it back on correctly lol.
02-28-2020, 08:53 PM | #9 |
Awesome, hopefully you get all this stuff sorted out and that's the end of it. Hoping your luck improves. Those clock springs are a PITA. I was so nervous about what I had read online about them being fragile that I bought a brand new one to have when I swapped to the ZL1 wheel. Thankfully I never needed it.
02-29-2020, 07:27 AM | #10 |
Drives: 14 2SS/RS Triple Black Ragtop LS3 Join Date: Mar 2014
I just LOVE stories that end well.
(see, I said nothing about 'happy endings') D'oh! -S
Come see the violence inherent in the sysadmin.
