02-21-2020, 06:33 PM | #1 |
Drives: 2016 Summit White Camaro SS (2SS) Join Date: Oct 2016
Power Stop Brakes
I'm going to show some ignorance here but please bear with me.
I'm sick of the brake dust on my wheels and the work it takes to keep them clean. My summers are in for ceramic coating but I figured adding some Power Stop Brakes would help all the more. What I've read up on them, they're not great for tracking but fine for dailying which is what I do with the car. So I ordered some pads off of Amazon only to see someone posting on Facebook that you can't go with just pads alone and that you need to either get the rotors too or at least have the rotors resurfaced. Is it true that you can't simply drop in new pads and either need to resurface the rotors or swap out to new rotors? |
02-21-2020, 06:46 PM | #2 |
Drives: 2016 Camaro 2SS Join Date: Mar 2018
No you don't HAVE to have the rotors also. I had PS Ceramic brakes on 2 of my previous cars and they were fine. In fact on my son's 2000 Camaro years ago they were a ton better than the stock in stopping power. My SS has the Brembos, I went with Ceramic but don't remember the brand, they are also fine.
If the car shimmies when you brake or there are grooves in the rotor surface, they will need to be resurfaced/replaced. Mine were fine, I didn't resurface, that was about a year ago and ~ 6K miles. No Issues any my car currently has 40K miles.
Mr Russ
Tim "the tool man" Taylor is my hero My Garage: '16 Chevrolet Camaro 2SS, Summit White, Adrenaline Red -- Rotofab CAI, Soler TB, 1 7/8 coated LT's, Full 3" mids, 3" Stainless Works NPP mufflers, Flex Fuel, E85/91 tuned '20 Honda Oddysey Elite 25th Anniversary Edition --wifes car, she said "No more SUV's" after the 2 CX-9's totaled |
02-21-2020, 06:48 PM | #3 |
just do a light coat of sandpaper on your rotors before you drive it after you swap the pads out its super easy
02-21-2020, 06:49 PM | #4 | |
02-22-2020, 06:32 AM | #5 |
Drives: 18 1SS/1LE Join Date: Jun 2018
I didn't even sandpaper or otherwise prep my 1LE/Brembo rotors, dropped in the Z26 and followed the break-in procedure...multiple hard braking 60-10 runs and Ive been good to go ever since. Great pads, 1000% less dusting.
02-22-2020, 07:43 AM | #6 |
Drives: 2016 F150 Join Date: May 2019
It's good practice to swap rotors too if they have significant grooving from your old pads, but if they are smooth and little miles then should be ok.
02-22-2020, 07:53 AM | #7 |
Drives: 18 ZL1 A10 Join Date: Nov 2008
use a name brand brake cleaner, YES it matters!! scuff the rotors with 800 grit and you will be good to go. I wouldn't cut the rotors, they are thin already and once you overheat them you will start to get shimmy...:(
I DD my powerstops without issues. just know, you will lose the initial bite of the stock pads but they stop pretty good. 95% dust improvement.
2017 ZL1 M6 Bog City, 2013 ZL1 M6, 2010 2SS M6
ZL1::J-E-T-S JETS JETS JETS |
02-22-2020, 07:53 AM | #8 |
Drives: 23 LT1/22 Colorado TB/69 Chevelle Join Date: Jun 2006
I had the Powerstop Z26 on my 1LE for 4 months and just switched back to the factory Brembos 2 weeks ago. The Z26s didn't have near the same stopping ability and they squealed no matter what.
02-22-2020, 07:58 AM | #9 | |
Drives: 19 Camaro SS 1LE, 03 Ford Lightning Join Date: Nov 2019
I've gotten to the point where I don't even try bedding the brakes with multiple hard near stops when I do a brake job. I just go out and drive it for about 20 or so minutes making sure I use the brakes a decent amount during that drive. Never had an issue when doing this, but I lost about all my petal pressure one time trying to bed the brakes on my L by doing a bunch of hard near stops from 60+ MPH. |
09-14-2020, 02:38 PM | #10 |
Drives: '17 Camaro 2SS & '99 Camaro Z28 Join Date: Feb 2014
Resurrecting this from the dead.
I need new Brake Pads. I hate all the dusting my stockers do, its a total PITA. But I don't want to lose 'too' much braking power. I eventually intend to track the car as well. Are the Power Stops for me? If not, are there any other pads you would recommend? Or would I need to swap to a larger caliper? |
09-14-2020, 02:45 PM | #11 | |
Drives: 2017 1SS 1LE Join Date: Jun 2016
2017 SS 1LE.
09-14-2020, 03:36 PM | #12 |
09-14-2020, 04:22 PM | #13 |
TD
Drives: 2017 2SS, 2014 Mercedes C300 Join Date: Feb 2020
09-14-2020, 04:36 PM | #14 |
2020 Shadow Gray 2SS
I put them on my 2020 2SS at 400 miles because of the horrendous brake dust... Helped a huge amount!
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Fender Badge, Footwell Lighting
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... BOTH are a lot of fun to operate... |
