01-15-2020, 07:33 AM | #1 |
Drives: Camaro ZL1 Join Date: Jan 2020
Header and cam install price.
Got a quote from a local shop to get headers and cam package install with all the supporting mods for the cam and dunk tune. The quote was $6,400 is this to high of a price for this?
01-15-2020, 07:44 AM | #2 |
Drives: 2019 Chevy Camaro ZL1 1LE Join Date: Nov 2019
You'll need to provide more details on the parts.
01-15-2020, 08:19 AM | #3 |
Parts
01-15-2020, 08:34 AM | #4 |
Drives: E92 BMW M3 Join Date: Oct 2012
Do you know the brand of headers?
J-Rod Built and Matt@FSP Tuned |
01-15-2020, 09:15 AM | #5 |
I have the headers they are 2” TSP, they are just installing them
01-15-2020, 09:50 AM | #6 |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
sounds about right since they are pulling the heads it appears. Most cam swaps i have seen posted are in the $5k range parts/labor. But you are getting headers installed and they are pulling the heads. Only part that sounds a little high to me is the Tuning cost.
Sold 2012 2LT RS 12.3@112 old setup
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
01-15-2020, 10:09 AM | #7 |
Drives: 2010 RS/SS Join Date: Dec 2010
Sounds about right. Labor is going to be high on the Gen V motors, you have to pull the heads to change the lifters and also drop the oil pan (two things you didn't have to do on the cam installs for previous gen ZL1).
Tuning cost seems a little high to me, but if it is a good reputable tuner, then that's fine. The tuning is complicated on these cars also so you want someone who is going to spend the time to get it right. The dyno part is simple it is the driveability that takes so long. |
01-15-2020, 10:13 AM | #8 |
I agree with the tuning. It should be about half or 2/3's at most.
The rest is average. You're not getting a deal and you're not getting screwed if it's a reputable shop. |
01-15-2020, 10:15 AM | #9 |
Drives: 18 ZL1 nightfall grey A10 Join Date: Apr 2018
Sounds about right. The tuning sounds high but if this is with the 4 credits needed to unlock, dyno tune, and street tune then it’s right. I see you are adding lower pulley to it as well. Might consider going to a 9.17 lower and since the blower is off get it ported and bigger throttle body. Could save a little money by using a soler 95mm instead of a NW 103. Car should make crazy power for maybe 2k more.
01-15-2020, 10:15 AM | #10 | |
The last thing you want to skimp on is the tune. If that is a very thorough tune, with a lengthy drive street tune included with dyno time, then I wouldn't worry too much. My 5th Gen cam tune cost me $500 from Matt Sorian and he drove it for quite a while while tuning it. I would expect a 6th Gen ZL1 tune to cost more anyway. OP, good luck on the build. It is exactly what I would do if I was lucky enough to have a ZL1.
01-15-2020, 10:16 AM | #11 |
Drives: 2018 ZL1 Join Date: Oct 2019
What year is your car? If 17 or 18 I would have them replace the oil pump while in there.
2018 ZL1 A10 - Rotofab Intake, LT5 TB, TSP Headers, ATI Balancer, 9.1 Lower Pulley, JMS BAP, Flex Fuel.
01-15-2020, 10:26 AM | #12 |
It’s a 18, and why go with a 9.17 lower?
01-15-2020, 10:31 AM | #13 |
9.1 lower will give you 2 more lbs of boost. They have to remove the balancer to do the cam so it wouldnt cost any more in labor to do the 9.1. It will add $600 to the cost though
01-15-2020, 11:48 AM | #14 |
It will not cost more than what is already quoted since the ATI damper and 9.06” pulley are on the bill now. You will only need to go with the 9.17 rather than the 9.06”.
