Go Back   CAMARO6 > Technical Camaro Topics > Dragstrip and Launching Discussion
Old 01-01-2020, 06:03 PM   #1
turboalb
Drives: 2016 camaro ss
Any nitrous cars here
Post setup/mods , Dyno, track times
turboalb is offline   Reply With Quote
Old 01-06-2020, 09:18 AM   #2
FdeleonZ28
Drives: 2016 camaro ss convertible
rotofab/jbaheaders/pray stage one cam/circled 3c/ported msd/95mm tb...havent ran full kill on spray, on a 50shot i went 10.7@129 with 2500da. put down 620hp and 670trq on a 125shot. all motor put down 520/495. ill be focusing more on spray this year.
FdeleonZ28 is offline   Reply With Quote
Old 01-07-2020, 07:50 PM   #3
turboalb
Nice set up, are you full weight? I'm about to start gathering my n2o parts over the next couple months. Probably a 100 shot
Old 01-08-2020, 08:22 AM   #4
LARRY01Z28
Drives: 2001Camaro Z28
if you live in NC you might want to get with Pray Performance.
LARRY01Z28 is offline   Reply With Quote
Old 01-08-2020, 11:27 AM   #5
turboalb
What did you're car run on motor?
Old 01-14-2020, 12:37 PM   #6
FdeleonZ28
all motor at 2500da I was usually 11.00-11.04.
and for weight im at 4k with me in the car. no muffler and no xbrace(verts only)
Old 01-18-2020, 06:06 AM   #7
turboalb
Thanks slowvert, with that 125 shot, with a drag pack set up I think you go 10.0's if not, a little weight shedding will get you there.
Old 03-02-2020, 09:24 PM   #8
jorgesvlog
Drives: 2019 Chevrolet SS
I just got all my Nitrous Outlet stuff in for the nitrous kit i plan on running in a month or two. I went with an MSD hard line kit with 15lb bottle. I also got a stand alone fuel system from nitrous outlet to be able to run c16.
My current set up is Cam/heads, FBO, e85 with ported everything pretty much. car put down 520/450 on a mustang dyne in 5th gear. Im hoping to spray a 100-150 maybe do a 200 once or twice lol
Check out my youtube channel. I just posted all the parts I got for my nitrous kit.
www.youtube.com/jorgesvlog
jorgesvlog is offline   Reply With Quote
Old 03-14-2020, 05:47 AM   #9
turboalb
I saw you're video the other day, I got the nitrous outlet x kit and working on a stand alone , I'd stay away from the 200hp, a 125 shot is really going to surprise you, these cars with heads and cam typically pick up close to double the torque that you spray . Use a progress, ive got one to easy the torque hit down low, your transmission will appreciate it. My friends 18 bolt on coyote runs 11.20 on motor, with the same kit with the 125 shot it pick up 1.1 seconds in the 1/4 and 15 mph, went from 1.61 sixties to 1.45.
your torque at 450 is going to be 650/700 on a 125 shot
Old 03-21-2020, 11:08 PM   #10
Gen5&Beyond
Gen5&Beyond's Avatar
Drives: 2016 2ss Camaro
Pray Performance H/C and converter with Nitrous Outlet hard line kit. Skipping 1st gear went a best of 9.55@145 on a 150 shot. Upgraded to lt4 low side is the only fuel upgrade. Standalone waiting to go in and getting a progressive controller and try spraying out of the hole for better et.
HBM 2016 2SS A8 NPP
427 Pray Head/Cam/Converter, Pray Ported Highram, 103mm TB, Pray Tuned, 3030 Drag Pack, Roark OTR CAI, TSP Headers, E85, UDP
Best times 1/4 n/a 9.23@146.96, 1/8 5.91@118
Gen5&Beyond is offline   Reply With Quote
Old 05-16-2020, 06:39 AM   #11
turboalb
Nice times on motor,do you have rods, pistons? you launching in 2nd or waiting to shoot in 2nd? lots of potential left!!!
Mine will be ready today, been super busy with work, but just got to finish wiring up and flow the fuel. I run 10's on motor on a nitrous converter and 116 lsa cam, heads are ported for nitrous too(exhaust valve area)
