12-03-2019, 12:42 PM | #1 |
Drives: 2011 Camaro Join Date: Sep 2019
Cadillac Swap v6??
My 2011 Camaro needed an engine. A Cadillac engine was purchased as a replacement. 3.6L engine, automatic. Why is the Cadillac engine $1K cheaper than the Camaro engine if, according to my husband, it's the exact same engine??? Aside from the oil pan, he says they are identical. He can't seem to explain the price difference and I'm suspicious.
Is this Cadillac engine even going to work in my Camaro?? Or is it going to be a nightmare and he will wish he spent the extra $1K?? I can't find any info about a successful swap. Is that because they don't exist or it's too common to bother discussing?? |
12-03-2019, 12:55 PM | #2 |
If it's the same rpo it's the same engine. Some things might have to be changed over from the old engine to the new, common things are, front cover, oil pan, for different accessories and locations.
12-03-2019, 01:02 PM | #3 |
Drives: 2010 RY 2SS/RS Join Date: Dec 2007
They are both the GM LLT engine, not sure what minor differences their may be but I would expect the differences would not be in the actual engine but perhaps tuning, oil pan as you husband states, and other accessories which probably are not even sold with the engine.
If you buy the short block they are the same. Long block which just means it comes with most of the necessary accessories there may be some differences. I expect it is just marketing that makes the difference, possibly more people need to replace engines on Camaros than Cadillacs?
12-03-2019, 03:25 PM | #4 |
Drives: 2015 Camaro Join Date: Aug 2018
You sure they're the same? The Camaro V6 might have different profile cams for more HP.
12-03-2019, 04:18 PM | #5 |
No, I'm not sure they are the same at all. My husband says they are... I'm going to ask Google right now about hp differences.
12-04-2019, 08:56 AM | #6 |
There are slight hp differences but that really means nothing just as when GM increased the the HP from one year to the next (I think that was 2010 to 2011) on the v6 and said there was no change to the engine and that they just under reported the hp the year before.
There probably is a tuning difference and probably some other differences but those are really in things attached to the engine and not the engine itself. They may have difference ECM tunes, oil pan, throttle bodies, exhaust, maybe even cams, ect. except for the cam they are all separate parts and not the engine. If the Cadillac has a difference cam basically all that likely means is that you may end up with 5-10 less hp but a smoother running engine. Typically a Cadillac would have the engine turned to run smoother and nicer and giving up a couple hp to achieve that. I doubt it but the only issue I could imagine would be if mounts are different somehow but probably not.
12-04-2019, 09:03 AM | #7 |
Drives: cheby Camaro Join Date: Aug 2019
From the info I found all the 3.6 engines are the same except for a oil pans-covers. The difference in HP ratings is in the tune. The Camaros were tuned to the very edge.
12-04-2019, 10:02 AM | #8 |
Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
Do you have the part number of the engine you are getting?
For reman engines, the CTS and Camaro use the same part number with a note - may have to swap pan. Some of the replacement engines are "partial" and do not include stuff like the intake. Which may be the price diff. I'd bet the content on how complete the engine is accounts for the price diff, vs model. |
12-04-2019, 11:29 AM | #9 |
Seems to me the difference in price is the fact the Camaro engine is rated at more HP. Its only a rating the engines are identical inside. Funny how that works lol.
12-04-2019, 12:20 PM | #10 |
So, bottom line, it will work. If it is in the tune, it will have the higher HP as you are already Camaro tuned. I doubt the cams are different for a few HP difference.
12-04-2019, 12:31 PM | #11 |
Both a CTS and Camaro show the same part numbers for replacement engines. The only price differences I see are; new vs reman or how complete the engine comes. Any HP diff would be from the exh/int/tune.
What are the two part numbers that are a thousand difference? |
12-05-2019, 02:09 AM | #12 |
The thousand dollar difference was at the place my husband found the replacement CTS engine. One was from a Camaro, the other a Cadillac. Similar mileage, identical engines (except the oil pan). Which is maybe where a portion of the price difference comes in? If I didn't have a Camaro oil pan/pick up tube, I would have to buy them. Obviously they are included with the Camaro engine. Maybe that's some of it? I won't lose any more sleep over this. I'm just so happy to hear that it will work in my car. Thank you all so much.
12-05-2019, 10:50 AM | #13 | |
ABM #2399 2SS/RS:SOLD
12-05-2019, 01:06 PM | #14 |
Who is doing the swap for you?
cadillac, swap |
