11-17-2019, 06:05 AM | #1 |
What has happened?
2010 SS Drove around last nite for about 45 min. Stopped by a store for about 15 min. When I tried to start the car, it acted like the battery was about dead, very weak. Turned switch off, and back on and the motor turned over several times (more than usual and very slowly) and started. Messages "open and close drivers window", and "service stabil trac" came on, the tach quit working, and the motor sounded and acted like it had a fouled plug all the way home. Any ideas?
11-17-2019, 06:46 AM | #2 |
It don’t come easy.
Sounds like the battery is at the end of it’s life. Wouldn’t hurt to check charging system, as well.
11-17-2019, 07:08 AM | #3 |
10-bolt Destroyer
Drives: 2012 Camaro 2SS/RS - AGM, LS3/6M Join Date: Jun 2012
Your battery is dead for sure and maybe the alternator isn't charging but you'll need to check that after you put a new battery in it.
Sent from my LG-H933 using Tapatalk
2012 Camaro 2SS/RS - LS3/TR6060: Cam, Headers, Exhaust, Intake, Gears, Twin Disk, Suspension, Tuned - 475rwhp, 443rwtq |
11-17-2019, 07:18 AM | #4 |
Drives: 2012 ZL1 Redline Phase 4 Join Date: May 2017
Ya man what they said, Battery's gone...
Same thing happen to me a couple of months back and my Batt was less than a year old. Service stabil trac, open and close window code, tach stopped working, heads up display stopped working, and .... New Batt Time
2012 ZL1 w/Redline PHASE 4-ZL Performance Package
11-17-2019, 01:05 PM | #5 |
Drives: 2015 1LE Join Date: Oct 2015
If that is the original battery its 9 years old, its gone!
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
11-17-2019, 04:37 PM | #6 |
Drives: 13' 1LE Join Date: Apr 2012
You can check the red plastic box on the pos side near the post; sometimes theres something loose there.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
11-17-2019, 04:53 PM | #7 |
Drives: 2011 2SS/RS Join Date: Feb 2016
Needs replacement. I recommend ACDelco 94RAGM Been using it for a year now with my ground upgrade for the engine to chassis and 0 issues.
•2011 Camaro SS 2SS/RS A6
•MRR M017 1le Replica Wheels •Vararam Ram Air Intake •Speed Engineering Longtube Headers w/ Magnaflow HF Cats •Bo White PnP Stage 2 TB •GPI SS2 VVT Cam w Cometic thin gaskets 10.69 compression •Xpipe w/ Res Delete and NPP Exhaust •Tuned By Anonymous Calibrations •Gen5DIY Mylink Conversion W/ Backup Cam •Morel 3 way custom speakers, Infinity 860w Subwoofers in trunk baffle •Helix P6 6ch amp w/ 8ch DSP and P1 Sub amp |
11-18-2019, 08:02 AM | #8 |
That was it! Thanks for all the info. I never thought a weak battery could cause so much chaos.
11-23-2019, 06:43 AM | #9 |
old school chevy rodder
A really slow start from having starter heat stroke does the same thing...…….
