Old 10-25-2019, 10:14 AM   #1
jericho_17
Drives: 2017 Camaro 1LT
V6 front jacking point
Has someone has a picture of the undercarriage of a V6, I would like to see how the front jacking point looks like not the side ones but the one in the middle.
jericho_17 is offline   Reply With Quote
Old 10-25-2019, 10:57 AM   #2
HCI2000SS
HCI2000SS's Avatar
Drives: 2018 Camaro V6/RS
When swapping out wheels on my V6 I couldn't find anywhere except just behind the front tire. I'm curious to know this as well
HCI2000SS is offline   Reply With Quote
Old 10-25-2019, 03:40 PM   #3
arpad_m
arpad_m's Avatar
Drives: 2018 Camaro 2SS A8
This is the official shot of the "base" (non-ZL1) undercarriage with the pinch weld lift and jack points highlighted.
735 rwhp | 665 rwtq
3000 - 2/06/18 TPW 2/26/18
arpad_m is online now   Reply With Quote
Old 10-27-2019, 05:38 PM   #4
302Blue
302Blue's Avatar
Drives: 2017 Camaro V6 1LE
I may be wrong, but I remember looking and seeing that the front jack point is covered by a metal panel. I assume to use it you'd have to remove it or risk damaging it, so I just use the pinch welds.
302Blue is offline   Reply With Quote
Old 10-27-2019, 11:35 PM   #5
arpad_m
arpad_m's Avatar
The pinch welds are the lifting and jacking points, see the rocker panel cutouts in the diagram above.
735 rwhp | 665 rwtq
Old 10-28-2019, 10:49 AM   #6
jericho_17
I've seen the pinch welds but it will be a lot easier jacking from a center point and then placing the two jack stands at the same time
Old 10-28-2019, 11:31 PM   #7
arpad_m
arpad_m's Avatar
If you jack from the second cutout in the front (to the right of the number "1" on the diagram), doesn't it raise the entire side of the chassis so you can slide in both jack stands? This is the recommended method as far as I know.
Skip to 4:25:
735 rwhp | 665 rwtq
Old 11-02-2019, 09:48 PM   #8
ItsChristianInHD
ItsChristianInHD's Avatar
Drives: 2017 Camaro 2LT RS 3.6L
Arpad is right. There are cutouts in the skirts. Jack from they're only. Anywhere else will damage it.
ItsChristianInHD is offline   Reply With Quote
