09-16-2019, 12:06 AM | #1 |
Drives: 2017 2SS M6 Vert Summit White Join Date: Jul 2018
Sliding panel broke
I use my top ALOT. Some days I will cycle my top 6x’s. I’m know that this issue has happened to others. I had no warning. No weird noises.
Not sure of the precise part name but the piece that slides on the metal track that pushes the plastic panel that hides the top mechanism when the top is down broke. This caused the panel not to retract when I tried to put the top up. The panel then popped the top plastic piece behind the drivers seat and broke the sliding panel. Going to the dealer tomorrow to order the pieces so it can be repaired. Not sure why it did not retract. I had no idea it was happening since it was on the drivers side until it was too late.
2017 2SS M6 Vert Summit White; aFe CAI, E85, dyno tuned; Bigworm Graphix, various exterior mods
09-16-2019, 02:38 PM | #2 |
Drives: 2018 ZL1 Convertible Join Date: Oct 2018
this happens often enough my dealer had all the replacement parts in stock. i was in and out within 1 hour. good luck!
09-16-2019, 02:59 PM | #3 |
Drives: '17 2LT/RS 2.0T M6 50th Anniv Vert Join Date: Feb 2019
Not sure if you read thru this thread:
https://www.camaro6.com/forums/showthread.php?t=531151 My issue was the panel did not break but would not open. Was like that from when I first bought my car earlier this year (it was a leftover 2017, purchased new in Feb '19). This is the link to the TSB which does indicate potential for parts breaking: https://static.nhtsa.gov/odi/tsbs/20...39149-9999.pdf Good Luck! |
09-16-2019, 03:13 PM | #4 |
Drives: 2016 Camaro 2SS Convertible A8 Join Date: Apr 2019
Does anyone have the part number for the plastic piece that slides along the aluminum rail? It's the one that actually moves the plastic door.
09-16-2019, 03:36 PM | #5 |
Drives: Camaro 1SS A8 Vert Join Date: Sep 2018
Yes
09-17-2019, 05:33 PM | #6 |
Does anyone have the part number for the plastic piece that slides along the aluminum rail that also would like to share that information with me?
09-17-2019, 08:46 PM | #7 |
Thank you Al Oppenheiser!
I trust it is not molded into the part...
The closest I could get is the tonneau hinge, but it’s not clear that it comes with the cover. Might be worth a stop at the dealer parts counter or a call to that gm parts guy. https://www.gmpartsoutlet.net/oem-pa...bC12Ni1nYXM%3D |
09-21-2019, 12:03 AM | #8 |
Went to the dealer and was told that this has happened enough that there is a TSB for it. Also, there is a “kit” they ordered. When it gets replaced I will post the info from the service invoice.
09-22-2019, 06:05 AM | #9 |
Drives: Wild Cherry LT1 Join Date: Dec 2016
10-03-2019, 10:26 AM | #10 |
Drives: 2017 2SS Join Date: Sep 2019
Did your top get stuck in the up or down position? Looks like down but want to confirm...
10-09-2019, 06:03 PM | #11 |
Drives: 2017 Camaro Convertible SS Fifty Join Date: May 2018
SOB, 2nd time in 13 months.
Just happened, put the top down and there is a gapping hole, the sliding panel stayed stuck (been telling these dealers it makes noise, oh that is normal), so pulled it back, hoping to avoid a dealer visit, and it began to pull up the panel. Good times. Guess I will have them look at the squeaky front brakes and jolting transmission issue. Anyone have a TSB on the brakes issue?
2017 Camaro SS FIFTY Convertible
10-12-2019, 09:12 AM | #12 |
Drives: 2017 2SS / 2003 S10 Crew Cab Join Date: Oct 2019
I had the driver side replaced this week. I asked the tech why the window regulator would possibly need to be replaced. He explained that the extra clip added to the newly designed trim panel attaches to a slot in the regulator and earlier version regulators did not have the slot. The entire repair took less than an hour. Kudos to McLarty Daniel Chevrolet in Springdale, Ar for a great service experience!
Never say never! |
03-27-2020, 02:25 PM | #13 |
SO has this been designed out for the later MY cars? I.E. fixed now for later MY?
03-27-2020, 04:52 PM | #14 |
Drives: 2017 HBM 2LT RS Convertible V6 A8 Join Date: Jan 2018
