#1 |
![]() Drives: 2010 Join Date: Dec 2018
A/C help
I have a 2007 charger with a 5.7 engine. This is not my car but a friend of mine. I have it back to look at the a/c again. I replaced the compressor (I replaced it because it failed originally) filter, and expansion valve. When I did this a couple of months ago it was very cold out of the vents. He came back to be and said that it had stopped blowing cold. So I did the usual visual inspections, made sure the compressor was engaged, looked for obvious leaks at all connections and rubber lines. I found nothing. So I hooked my gauges up and the pressures were spot on. I did opt to recovery the 134 and open the system up mainly to clean the condenser core. I drained all the oil from the whole system and flush it again. Recharged and nothing. The pressures are as follows 35 low 200 high. I have 75 degrees blowing out of the vents. I will also add that I pinched off the heater hoses to restrict water flowing to the heater core. Suggestions from a/c tech welcome.
