Old 08-08-2019, 01:14 PM   #1
anthony.martinez
Drives: 2010
Evapo-rust
Does anyone use this stuff? I work for a company that deals with a lot of parts some of them that require cores to be turned in. Recently I returned some cores to our local cat dealer and they sent me an email stating that the cores were rejected because of excessive rust. They did have some rust on them due to an internal water leak. It is stated that one can not even clean them (unsuccessful attempt to salvage) as per the core acceptance criteria. Longer story short I had purchased some Evapo-rust from summit and this stuff is amazing. We took 12 other rocker arm cores and placed them in a gallon jug for about 6 hrs. No scrubbing at all and look at the results.
anthony.martinez is offline   Reply With Quote
Old 08-08-2019, 01:21 PM   #2
anthony.martinez
Drives: 2010
2 cleaned rockers
Old 08-08-2019, 02:36 PM   #3
Expunge
Expunge's Avatar
Drives: 2013 ZL1 M6, '99 Tahoe 2Dr Sport
Nice
Expunge is offline   Reply With Quote
Old 08-08-2019, 10:41 PM   #4
chef-beavis
chef-beavis's Avatar
Drives: IOM 2013 2SS/RS, Greenie, 06 FXSTBi
I used something like this years ago in a motorcycle tank that got rusty inside. The stuff was paint friendly, non-toxic, plant-based, pour it down the drain when done, and expensive as hell. Lol Worked great, though.
How expensive is this stuff from Summit?
chef-beavis is offline   Reply With Quote
Old 08-09-2019, 01:37 AM   #5
anthony.martinez
Drives: 2010
80 bux for 5 gal. reusable
Old 08-09-2019, 09:45 AM   #6
I too use a product that is similar, that I came across nearly 35 years ago and still use....its called OSPHO and is still available, back then I got it at a marine supply store, now you can actually order it off Amazon. the last time I bought some, it came in the same 32 oz. bottle that the original came in that I bought 35 years ago. its the consistency of water....and it too is reusable. I have even used it on rusted parts of a frame.....wired brushed off the flaky stuff and used a cheap paint brush to coat it and let it dry....done deal.
Old 08-09-2019, 09:59 AM   #7
I just did a search on line..... and Evapo-rust is a lot easier to get other that getting it from Summit, as its available from Lowes, Amazon , Tractor Supply, and Home Depot, at Home Depot a 5 gal. bucket is $76.
Old 08-09-2019, 10:04 AM   #8
anthony.martinez
Drives: 2010
this is far from ospho. I used that many years ago too. If memory serves me correct it is a bit corrosive.
Old 08-09-2019, 10:07 AM   #9
anthony.martinez
Drives: 2010
I have never seen it at any of those places. I will certainly do a search for store availability. I will be purchasing 3 more buckets of this.
Old 08-09-2019, 11:50 AM   #10
BMR Sales
BMR Sales's Avatar
Drives: Race Car
https://www.homedepot.com/p/Evapo-Ru...R013/300223745
Old 08-09-2019, 01:30 PM   #11
1911 1LE
Drives: 2015 SW 2SS 1LE
Anthony, I have some antique tools and "flood guns" I'm going to try this on. If it works as good as it's supposed to, I owe you a Bud Light
Thanks for the tip
Maggie 2650 @ 18psi/ 75mm 10 rib/ Dual alky nozzles/ Roto-fab/ ARH 2" Lt's/ GT-12 cam/ ZL1 3.23 Conv./MGW/RPS triple carbon clutch/RSG tranny upgrage/Pedders Ex. XA w/ remote cans and a lot of other crap 897/8??@tires
1911 1LE is offline   Reply With Quote
Old 08-09-2019, 03:40 PM   #12
anthony.martinez
Drives: 2010
not in stock at my store. but I can order and get it from them. btw summit is now 96 bux. this will save me (my company) 60 bux for 3 pals. Thanks for the link
Old 08-09-2019, 03:46 PM   #13
anthony.martinez
Drives: 2010
Thanks for the tip
lol...I wished this stuff was around when I was building all the engines I have built in the past. I would have saved many many hours of wire brushing, varsol dipping time. Good luck with your new projects
Old 08-09-2019, 04:12 PM   #14
5thgenlife
Drives: zl1
Muriatic acid. But dont get the "green" or less fumes kind. It doesnt work as fast. Use is well ventilated area.
5thgenlife is offline   Reply With Quote
