07-14-2019, 12:01 AM | #1 |
Drives: 2014 Summit White ZL1 Join Date: Oct 2018
Low oil pressure or just paranoia?
Could use some insight on my "problem", I'd appreciate it. Story Time, haha. Sorry if it ends up being long winded, but I'd like to give as much info as possible. I have looked and read up on so many "Low Oil Pressure" related problems, on ZL1's and CTS-V's.
So a couple days ago I was driving my car and came upon a nice empty stretch of road, nothing but a red stop lighting holding me back. I eased onto the throttle in first and shifted into second, got up to 4k rpm's and let her rip. Now I had a new pair of shoes on, and I had never gone WOT with them, well, my foot kinda slipped off the clutch and I didn't hit third. No grinding or anything of the sort, just didn't get it in. Unfortunately, I hit the limiter, first time since I've owned the car. Fast forward, I'm driving down the freeway and look at my Oil Pressure Gauge, I'm cruising around 2,100 rpm's and it's reading 3.2-3.1 Bar. I always remember it being at 3.8 at cruise, unfortunately, I don't remember my reading at anything above that, other than it always went past 4+ Bar when I was closer to redline(5k+). So now, at idle I get around 2.2-2.5 Bar warmed up(90+ temps), and 3.4 Bar when at 3,500 rp'ms+. It doesn't get any higher as the rpm's progress, I've actually seen it drop .1-.2 Bar when getting above 5k. I drove it around today after changing the oil and it stays pretty consistent, but I can't help but wonder that it should be higher. Did a few WOT pulls and the psi values stayed the same, as mentioned earlier. Also, when driving and giving it gas and then letting off, the oil pressure will go up .1-.2 Bar. When changing the oil, I didn't notice any kind flakes, other than some gold/bronze glitter from the oil filter, but I believe that's from my CHE Trunnion kit. So could have hitting the Rev limiter(Limiter set at 6800, per my tuner) caused this new "problem" or am I just being paranoid? What do your guys Oil Pressure read as your rpm's increase? Mod List GP Tuning Stage 2 Cam(with Supporting Mods) Melling 10355 Kong Ported SC 10" Pulley ID1050x Headers Roto-Fab MM Catch Can Thanks for any help you guys can give. |
07-14-2019, 04:28 AM | #2 |
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500 Join Date: Apr 2015
Convert bar to psi for me lol
07-14-2019, 04:32 AM | #3 |
Team 913
Oil drop due to over reving would be damaged bearings. Unless the pump has an issue
you are at about the recommended max 23000rpm for the supercharger with at 10” lower and stock snout pulley with 6800rpm engine rpm If you cannot be sure of the oil pressure before the rev limiter incident, we cannot know that is the cause... I idle around 30psi warm I believe there is a bypass valve in the pump so the psi wont go through the roof We should gtg sometime... i see you are in my neck of the woods Last edited by Crash76; 07-14-2019 at 04:44 AM. |
07-14-2019, 09:03 AM | #4 | |
Drives: 2013 Triple Black ZL1 / 2006 TB SS Join Date: Feb 2011
Blower rpm aside, I'm still surprised to see so many spin these engines that high on stock heads with these heavy valves. I included some bar to psi conversions below.
If the oil pressure is dropping at WOT check the oil level first. The oil pump is crank driven, so the pressure will change depending on the engine rpm. This is not good and not related to the trunion kit: Quote:
Bar to psi approximate conversion: Bar PSI 1 15 1.5 22 2 29 2.5 36 3 44 3.5 51 4 58 4.5 65 5 73 5.5 80 6 87 |
07-14-2019, 09:04 AM | #5 |
Also check the catch can to see if there are metal flakes at the bottom.
07-14-2019, 10:55 AM | #6 |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
I don't see how you would ever get over 3.4-3.8 bar at WOT when hot unless you remove and plug the oil sump relief valve, which limits pressure to right around 3.8 bar. Even if you were to shim the 10355, it would still be limited at the top of the pressure range due to the relief. I guess you could run a very thick oil to get there, to the point where the relief can't keep up with the flow and thickness of the oil, I mean.
I just checked my data log from last week- at WOT, pressure is 3.2-3.4 at 2000 rpm and then stays between there and 3.4-3.6 bar max all the way to my 6700rpm fuel cut. I only see higher (and then only up to 3.9-4.0 bar) at initial start up in the morning and during the first 15 minutes or so of my drive when it's cooler outside. When hot and cruising, I see 3.2-3.3 bar. When hot at idle, I see 2.5 bar. My mods are about the same: 10", GP 2.5 cam, ported melling 10355, CHE trunions, etc. Is this your first oil change after the cam/ kit? If so, that might explain the brass from the CHE break-in. Also, what oil are you running? I run Redline 5w30- which is thicker than the off-the-shelf synthetic stuff of the same weight.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp // CSP LT's & Ultra Cats // Elite Ultra CC // BMR MM
Past Rides- 2014 ZL1 M6 Red Hot | Tons of mods 2004 CTS-V M6 Silver | Many mods 1995 Corvette M6 Torch Red | A few more mods 1992 Camaro M5 White | A few mods |
07-14-2019, 11:05 AM | #7 | |||
ZPE 2.90 Upper and DSX 9.84 Lower Yeah, that sounds good, I'm always down to meet new people/car enthusiast. I'm actually in Tracy, but frequent the Bay Area. Quote:
I did an oil change yesterday and checked my level, it's at the top dot/indicator. The oil pressure drops .1-.2 bar (1.47-2.94psi) once I'm about to shift, sometimes it doesn't move at all, very intermittent. As for the glitter I mentioned earlier, I'm going to try and post a pic. I was reading on another forum and it looks to be the same as to what I have, and they said it was from their Trunnion kit. Quote:
Thanks for your guy's insight, it's greatly appreciated. |
07-14-2019, 11:26 AM | #8 | |
95*-100* Ambient Temps 2000 rpm= 3.0-3.2 6500 rpm= 3.3-3.4(Seen it go from 3.4 down to 3.3 so far) Cold Start= 3.9-4.0(750 rpm) Does your oil pressure go down slightly when you're driving at cruise speeds and you let off the throttle a bit? Example: 2100-2200 rpm= 3.1-3.2 Bar Let off down to 1900-200 rpm 3.0-3.1 respectively. Then back up when getting back on the gas. Yes, this is my first oil change after the cam swap. I was and am running Pennzoil Ultra Platinum before and now after the oil change. I always wondered if I should change the oil weight due to my area's temps and the cam swap, maybe to a 5w-40? As for the brand, there are so many to choose from, I just used what was readily available. I read Redline, Amsoil, Royal Purple, Joe Gibbs. It's so hard to pick, I might try Redline or Amsoil next. I appreciate your input! |
07-14-2019, 11:40 AM | #9 |
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled Join Date: Jun 2019
looks like glitter
07-14-2019, 01:23 PM | #10 | |
fo'shizZL1
I'd be willing to bet the flecks you see are from the CHE break-in since this is the first oil change- that said, hopefully your builder used some sort of assembly lube on all of the fresh components. Regarding oil brand, a good full synthetic is the way to go with the increased spring pressures pushing on the lifters and higher RPM that come with a cam. Personally, I'd only run Redline, Joe Gibbs LS Driven, or maybe Amsoil. I'd avoid anything off the shelf, honestly (Mobil1, Pennzoil, etc.). I know that's personal opinion, and oil is highly controversial, but most people running higher HP builds swear by one of the three I mentioned. Speaking of GP cams, I believe Matt recommends and uses Redline and Driven in his builds. I'd think a 5w30 would be fine, and I know some will run a 5w40, though. Just remember that the better oils have a higher viscosity than the off-the-shelf stuff at the same advertised weight- e.g., I believe I read that the Redline 5w30 has the same or higher viscosity as Mobil1 5w40.
07-14-2019, 02:32 PM | #11 | |
I'm starting to feel a little more at ease after all your guy's input, maybe I was just being paranoid, since I thought I might have hurt something when hitting the limiter. Just for anyone else in my situation, I'm going to update the thread later, after the oil change. |
07-14-2019, 02:50 PM | #12 |
Big Crow
Drives: '13 ZL1 Join Date: Mar 2017
07-14-2019, 05:18 PM | #13 |
Drives: 41' Willys SEG , 59 Biscayne lowrod Join Date: Sep 2017
It may have been mentioned already but I vote for Redline as well and strongly suggest a WIX filter, I use the 57045XP. The belly pan needs the slightest trim to clear.
A proper filter cutting would show more info. I concur, the glitter is likely not bearings but the filter doesn't lie. Also FWIW my bone stock 14' has never made 4 bar and I've got 20W50 Redline in it. Good luck |
07-14-2019, 06:31 PM | #14 | |
Already got everything on order, Redline 5w-30 and Wix 57060XP. Ordered it before I saw your post, but that filter you mentioned seems quite a bit larger than the one I found to be for a ZL1. Unfortunately, I already threw away the old filter, but will be looking at the next one on Thursday. Everything is arriving on Wednesday. I don't really drive my car on the weekdays, but already did quite a bit of WOT pulls this weekend, so if anything, the filter will show if anything is out of the ordinary. |
