Old 04-09-2019, 11:05 AM   #1
Gasoline_Farts
Drives: 19 SS 1LE
Cadillac CTS-VR at Limerock (4k) iRacing
I managed a pretty stellar lap IMO (49.732) a personal best by over 4 tenths, thought i'd share:
https://youtu.be/TuOq2so62mk
here is the same lap but from the rear of the car, you can see the suspension working from this angle and you can see it get light over the crest
https://youtu.be/Nkv9oIdsMQI
(also 4K)
car specs:
Weight:
3200 lb
Engine:
6.2L, 90-degree V-8 with aluminum block and heads
Power:
460 hp @ 5400 RPM
Torque:
447lb/ft @4400 RPM
Brakes:
Brembo four wheel discs: six-pot front with 355 mm rotor, four pot rear with 328 mm rotor
Transmission:
Sequential six-speed transmission, no lift shift
Suspension:
Three-way adjustable dampers (shocks); front independent SLA,
race-modified; rear race-modified independent multi-link.
Gasoline_Farts is offline   Reply With Quote
Old 01-03-2021, 08:31 AM   #2
FarmerFran
FarmerFran's Avatar
Cool.
I love no lift shift
