02-05-2019, 04:23 PM | #1 |
Drives: 1999 Camaro SS Join Date: Apr 2016
Intercooler pump replacement idea...
2012 Camaro SS M6
Whipple supercharger Whipple heat exchanger Whipple Bosch pump RotoFab Reservoir tank Active Interchiller So my Bosch pump took a crap. So should I replace it with a ZL1 pump and be on my way or has anyone had experience with a Davies Craig EWP150 pump https://daviescraig.com.au/product/e...p-kit-12v-8060 Would the ewp150 be to strong of flow through my 2 gallon system? Is faster water flow better for a small system, by not allowing the water to warm up? Is the Stewart EMP over Kill? I know the price is Other ideas welcomed.... Last edited by 4U2NV-SS; 02-05-2019 at 06:35 PM. |
02-05-2019, 05:03 PM | #2 | |
Drives: 2011 Camaro 2Ss M6 Join Date: Dec 2011
02-05-2019, 06:37 PM | #3 |
P^^^PM me the price for your pump? Any pictures?
Yeah the emp is pricey. Not sure if it’s over kill for my small system |
02-05-2019, 06:55 PM | #4 |
'It's an experiment'
Varimax is the way to go. Get the pnp harness...
I have 2 in my system... -Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 |
02-05-2019, 07:48 PM | #5 |
Drives: 2011 Camaro SS/RS Join Date: Feb 2011
I went with the varimax. I have the active innerchiller as well
SLP TVS 2300- 1 7/8 LG Headers- RDS NX Plate- 75 Shot- No Cats- SLP Loudmouth 2- NW102- 3.8 Pulley- OD Cog drive-12lbs boost-FIC 80# injectors-ZL1 Fuel Pump- RotoFab CAI- Apex CAI Scoop- Pat G Tune- Weld RTS drag pack- BMR Trailing Arms- BMR 1'' Drop Springs-BMR Lower Control Arms- BMR Toe Rods- BMR Rear Cradle Bushings- BMR Upper Control Arm Bushings- BMR Extreme Anti- Rollbar- Hotchkis Subframe Brace- Prosport Evo Boost & F/A Ratio
02-06-2019, 02:57 AM | #6 |
Drives: 2010 SS/RS LS3 M6 Join Date: Apr 2011
The more water flow the better, flow drops pretty good from the restrictions and pressure in the system, a stronger pump will recover some of these losses and cool more efficiently.
02-06-2019, 07:35 AM | #7 | |
www.jannettyracing.com
02-06-2019, 09:54 AM | #8 |
Thanks guys!!!
Wish I could find some real info on these Davies Craig pumps. |
06-20-2020, 12:56 PM | #9 |
Drives: 2013 ZL1 M6, street tune ,LTH, CAI, Join Date: Jan 2018
I too am also interested in the Davies Craig pump as an intercooler pump for my rear mounted ice tank. I’d like to bypass the stock ZL1 pump and just use one pump in the trunk.
06-21-2020, 09:21 AM | #10 |
Just reading the description, it seems like the EWP150 might be a little bit overkill for your system. While I agree, that you want some speed of flow, it needs to be a balanced flow that maximizes heat transfer. If the coolant is flowing so fast through the intercooler and heat exchanger that it never has a chance to actually transfer any heat, what good is it doing you?
When my Bosch pump quit, I switched to the Varimax, and haven't looked back. I have the Active Interchiiler as well, and my IATs are always good. |
06-22-2020, 07:46 AM | #11 |
The engineering data I found on liquid cooling in heat exchangers indicate that faster is always better.
06-22-2020, 04:13 PM | #12 |
I have a 5 gal trunk tank with 3/4 lines, I am on my third bilge pump.
The bilge pumps don't like long trips that's for sure. A Varimax won't cut it for a rear mounted tank pump just simply not enough pressure or volume. I'm down to looking at Davies Craig, EMP , Pierburg or ?? If i had a small front mounted tank i would definitely go with a Varimax but i like adding large amount of ice when at the track. |
06-22-2020, 05:23 PM | #13 | |
"....Maintaining high rates of cooling water always promotes cooling: heat energy carried off per unit of time is increased. High cooling water flow rates increase heat transfer coefficients (by promoting turbulence), as well as keeping the cooling water at lower temperature, which further promotes cooling, as the heat carried off per unit of time is directly proportional to the temperature difference between the cooling water and the object to be cooled (see Newton's law of cooling). Of course there may be other, practical limitations to cooling water rates, such as pump rating and pressure build up. But within these margins, the faster the flow of cooling water, the better the cooling." |
