Old 01-11-2019, 09:50 AM   #1
Martinjlm
Retired fr GM + SP Global
Martinjlm's Avatar
Oh, it's just a battery change....
I am inclined to believe that there is a front row parking spot in the garage of Hell for whomever engineered the battery system in the Cadillac SRX. It required 4 different socket sizes, pliers, a screwdriver, a rubber mallet, hands smaller than mine, and at least 5% of my engineering degree to change the damn battery.
The fact that it was under 20 degrees was just bonus.
Old 01-11-2019, 10:13 AM   #2
rocket403
rocket403's Avatar
Drives: 80 Cutlass 403, 2010 FF RT
GM general mistake as my Ford friend would say
rocket403 is offline   Reply With Quote
Old 01-11-2019, 10:20 AM   #3
snizzle
Recalled user
snizzle's Avatar
Dammit Barra. Did I do it right?
2012 2SS 45th AE LS3 M6
Borla ATAK Catback
Kooks Stepped LT Headers
CAI Intake
Hexvents
VMAX CNC Ported Throttle Body
RX Catch Can
Hurst Short Throw Shifter
Forgestar F14
Tuned by Frost
snizzle is online now   Reply With Quote
Old 01-11-2019, 10:24 AM   #4
BMR Sales
BMR Sales's Avatar
Drives: Race Car
gotta try to keep the masses coming back to the Stealerships somehow!
Old 01-11-2019, 10:35 AM   #5
rocket403
rocket403's Avatar
Challenger has the perfect location the trunk LOL
Old 01-11-2019, 11:59 AM   #6
Vegas Bound
Drives: 2013 Sparkly Red One
Try changing a battery in a CLS550.
Old 01-11-2019, 03:09 PM   #7
DenverTaco07
DenverTaco07's Avatar
Drives: 2017 SS 1LE, 2017 Volt, 2013 Pilot
so... just like the Camaro.
2017 SS 1LE | HBM | Vortech V3-Si supercharger (620RWHP and 575ft lbs) | PDR | Black Bowties | Illuminated Front Black Bowtie | Illuminated Door Sills | Smoked Tails | vented seats mod
DenverTaco07 is offline   Reply With Quote
Old 01-11-2019, 04:17 PM   #8
JerTM
JerTM's Avatar
Drives: 2011 2SS/RS M6
As a GM tech for 12 years, I can attest to this. I really do believe that any engineer that plans on having their designs built should be required to do general maintenance on cars for 2 years before their designs can be made into a product. And once a year they are sent to a shop for a week to do more general maintenance on their own designs. I understand that the bean counters have a pretty heavy hand in what makes it into a car as well, and that manufacturing processes need to be taken into account but some things are just assanine how they were assembled it baffles me. I often come across things that would have been much much simpler if they had moved a bolt, put a bolt in from another direction, or changed the entire design completely. I can't count how many people leave complaining that it costs $85 for a head light bulb. The bulb is about $10, but I have to remove your entire bumper to change it. Don't get me wrong, I come across genius level components from time to time that just make life so much easier and cheaper for the customer.
JerTM is offline   Reply With Quote
Old 01-11-2019, 07:47 PM   #9
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
I figure its done because pretty much nobody buys a new car with 'ease of maintenance' as a priority. When buying used? Sure, sometimes. But not new. And most of those pain-in-the-ass things only come up after the warranty expires and likely with a 2nd or maybe 3rd owner. So its not going to cost GM (or any other automaker) extra to pay for the work to be done nor a new sale from an annoyed owner.
Meanwhile, all they get in return for doing a little more design for maintenance is a bit less less griping from mechanics (of both the professional & shade-tree varieties). Thats not worth much.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 01-11-2019, 11:32 PM   #10
JaxChris
Drives: '16 2SS GD1 MX0 NPP F55 IO6
Read somewhere that on the 2019 Ranger you have to put the truck on jacks and remove a wheel to swap the battery. No battery replacement procedure, unless its' an EV, should say "Step 1: Lift the vehicle".
JaxChris is offline   Reply With Quote
Old 01-12-2019, 08:05 AM   #11
xc_SS/RS
Drives: 2010 Camaro SS/RS
At least it's not a starter on a Northstar lol
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 01-12-2019, 10:25 AM   #12
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
One of the Chrsyler's is already this way, it's an '11 or '12 I think.
One of my old bosses had a car that the battery was under the back seat. In order to change it you had to tear apart the whole back half of the car. First you had to remove the trim along the doors and the back window to access the bolts holding the back part of the seat, then you had to remove the back to gain access to the bolts holding the bottom part of the seat so you can remove it to reach the reach the battery.
Old 01-12-2019, 07:37 PM   #13
KMPrenger
KMPrenger's Avatar
That was actually to get to the oil filter for doing an oil change...not the battery.
Now, new reports are saying you don't *really* have to remove the wheel, but you do have to turn the wheel all the way one direction to access a panel to get to the oil filter. Doesn't seem much better.
Old 01-12-2019, 11:09 PM   #14
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
Nothing surprises me anymore. BMW is worse. Not easy to get to, but the car has to be programmed to the exact size battery installed in the car, and even if you put an identical battery back in, the battery has to be "registered" to the car to tell the charging system there's a new battery in the car. If a new battery isn't registered, it won't last even a year at best, because the car charges a new battery differently than it charges an old battery.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads.
'Hellcat' sounds like some kinda 15 year old furry with liek "I'm a blue fox with wings and magical kawaii powers" kind of sh*t.
shibbs is offline   Reply With Quote
