01-10-2019, 09:13 PM | #1 |
Drives: 2018 SS 1LE Join Date: May 2018
eLSD calibration upgrade
Has anyone done the eLSD calibration upgrade & have results on the track (road & 1320) ?
🌽 Sauced, 2018 SS 1LE - 123mph @ 5,000 DA
ARH 2”x3” FULL System, Pray Ported MSD Intake Manifold, Pray Ported GM 95mm TB, RotoFab CAI, DsX e85 Kit, MightyMouse Catch Can, NicD Tune https://instagram.com/corn_sauced?ut...d=o0ako89uurwl |
01-10-2019, 10:19 PM | #2 |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
eLSD calibration changes nothing on street or track. It was designed for AutoX.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
01-10-2019, 10:32 PM | #3 |
I’m fully aware of the calibration... I’m looking for possible street & strip advantages. Did you do this calibration and take it to the track to comment on calibration?
01-11-2019, 08:23 AM | #4 |
Drives: 2013 BMW M3 Join Date: Jul 2016
It was put out for the autocross people. Specifically for Cam-C and other higher preparation classes since this is not legal for the 1LE in AS or now BS.
https://www.camaro6.com/forums/showt...=532096&page=3 Last edited by RKeeton; 02-14-2019 at 11:11 AM. |
01-11-2019, 08:28 AM | #5 | |
Daily Driven 1LE
Drives: 2018 1SS 1LE Join Date: May 2018
"This eLSD calibration will decouple the differential at a faster rate based on accelerator pedal position and steering wheel angle to enable faster yaw rotation at corner entry, and upon corner exit the eLSD will couple faster than normal rates to enable power to be delivered sooner to both rear wheels."
2018 1SS 1LE
01-11-2019, 08:37 AM | #6 |
Drives: 2017 SS 1LE Join Date: Mar 2016
If you turn the TCS/Stabilitrac completely off while on track (I know some people don't use PTM) the "Autocross Tune" will be active. Yes it was designed for Autocross but it should do the exact same thing on track, they don't market it that way though because their Autocross club guys are the ones that developed it and deep down they want you to use PTM while on track.
IG: @NC_M1SS1LE
01-11-2019, 08:45 AM | #7 |
Drives: 1LE Join Date: Sep 2017
Kinda ofc topic but I believe HP Tumers has the ability to edit MRC.
01-11-2019, 09:08 AM | #8 | |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
Hmm I may need to get this on my 1LE. With the addition of the Procharger now I am having issues that I know are coming from the rear end with the car wanting to walk all over the road as the rear diff locks and unlocks while under WOT. Does the improvement affect all PTM modes or only certain ones?
2019 Corvette Z06 2LZ A8 - Halltech CAI, AWE non-catted X-pipe, Mamo V2 ported TB 592rwhp, bone stock 566rwhp
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD |
01-11-2019, 09:39 AM | #9 | |
Drives: 2017 1SS 1LE Join Date: Aug 2017
Everything else is as delivered from the factory.
www.facebook.com/1lap1le
2017 1SS 1LE - 663 whp/623 wtq Rotofab/Whipple/Kooks 2"/LT5 TB/LT4 Fueling/E85/MCS Coilovers/Ground Control/GOODAero/Apex Wheels/Race Louvers |
01-11-2019, 09:54 AM | #10 |
Drives: 2017 SS 1LE HBM, 2010 SS FBO/Cam Join Date: Mar 2018
I wonder if they are going to release a drag calibration for the 1LE like they are doing for the ZL1?
https://www.camaro6.com/forums/showt...ht=calibration
01-11-2019, 10:25 AM | #11 | |
01-11-2019, 10:26 AM | #12 |
It could be both with a separate drag setting to reduce the bog and making standing burnouts possible.
Wishful thinking as I live 4 miles from a dragstrip.
01-11-2019, 10:44 AM | #13 |
Drives: SW 1SS 1LE / Jeep XJ Join Date: Mar 2016
Hold the Traction control button until it's fully off(two lights on dash) had no problems when I was at the track to spin the rears.
01-11-2019, 10:48 AM | #14 | |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
The calibration is designed mostly for autocross situations, yes, but it will come into play in low and medium speed circumstances on a road course. The reason that the calibration doesn't come into play at high speeds on track is to keep the car stable and safe at higher speeds on track. The increased decoupling on deceleration and increased coupling on acceleration is done to allow the car to rotate a bit better and then distribute power to both wheels sooner at low and medium speeds. These two things can make things very tricky at high speeds... The calibration is only available with TC/STAB off (PTM unavailable), as that is, really, the only way the calibration could be released. Having it available with the other modes on would require a lot more investment (validation time and money and certification) on GM's part. With the cal only being available with everything off, GM is able to release the calibration because it separates them from the investment and liability. |
