Vararam
Old 11-22-2018, 08:57 AM   #1
daytripr69
Drives: 2010 RS
random no start
2010 v6 rs wifes car. last week her car had trouble starting and replaces the battery because it was dead. all good until this week and car will sometimes not start. turn key nothing but a click sometimes others fires right up. turning key several times will get it to start. its not a voltage issue as everything works as it sould and starter speed is normal when it decides it wants to enguage.
daytripr69 is offline   Reply With Quote
Old 11-22-2018, 12:48 PM   #2
Overflow
Space Shuttle Aficionado
Overflow's Avatar
Drives: 2016 Camaro 2SS
I'm assuming you replaced the battery with the same CCA as the previous?
If so, then it may be the starter solenoid.
Old 12-23-2018, 12:06 PM   #3
Dead Eye
Drives: looking
More than likely starter. Mine is doing this exact same thing as of today. Definitely seems like every starter issue I've ever had.
Limited lifetime starter can be purchased for about $150.
Just trying to figure out the exact starter position.
Sent from my SM-G955U1 using Tapatalk
Dead Eye is offline   Reply With Quote
Old 12-23-2018, 04:46 PM   #4
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Either the starter is toast, or the starter ground wire is loose or has a corroded terminal.
