Old 09-25-2018, 07:58 PM   #1
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
GM Patents Clutch By Wire
A new patent from GM could mean your next clutch pedal is a digital one.
https://www.gminsidenews.com/article...ual-trans-fun/
Mark114 is offline   Reply With Quote
Old 09-26-2018, 05:31 PM   #2
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
That's pretty insane
CamaroDreams76 is offline   Reply With Quote
Old 09-26-2018, 05:52 PM   #3
JerTM
JerTM's Avatar
Drives: 2011 2SS/RS M6
Ford has a transmission in it's Focus(probably others too) that has a clutch disk, and is shifted by actuators. I have seen the guys across the shop changing the clutch and actuators quite regularly. Ford treats it like an automatic in that you select drive just like an automatic and it does the rest. An automatic clutch with a manual shift pattern and lever would be a lot more fun if the kinks can be worked out.
JerTM is offline   Reply With Quote
Old 09-27-2018, 12:00 PM   #4
NW-99SS
Drives: 1999 Camaro SS M6 - SBE LS1
The original Ferrari F1 (F1 meaning 575 Maranello, 360 Modena, etc) transmissions were this style - electric/hydraulic clutch setup with paddle shifters or full automatic mode.
1999 Camaro SS 6M - SBE LS1
1994 Camaro Z28 6M - Golen 383 HT
1963 Corvette GrandSport - ZZ502 4M
2017 Denali 1500 6.2
2017 Yukon Denali 6.2
NW-99SS is offline   Reply With Quote
