Old 09-18-2018, 10:07 AM   #1
Osbornsm
Drives: 2018 SS 1LE
Exclamation Camaro SS 1LE brakes suck (change my mind)
Good morning Al,
I just had my first track day with the SS 1LE Camaro!
Everything was great except the brake temperatures.
I boiled the brake fluid (Motul RBF600)
'18 Camaro
  • Fluid: Motul RBF600 bled 2 days before event
  • Pads: Raybestos ST-43
  • Caliper Temp = 500 F (after cooldown)
  • Rotor Temp = 650 F (after cooldown)
I thought the SS 1LE was FOR lapping days. It's designed with coolers, 2-piece rotors, 6-piston calipers, brake ducting...
And it STILL boiled the racing brake fluid (I exited the main straight @ 60mph into the grass).
So i come to you looking for recommendations.
Thank you kindly,
~ Sean
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si
Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8
Results: 470 hp / 447 tq
Osbornsm is offline   Reply With Quote
Old 09-18-2018, 06:47 PM   #2
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
sounds like your too hard on the brakes or you need to try the stock pads again
Old 09-18-2018, 07:57 PM   #3
24v
Drives: 2018 SS
Less brake, more gas.
24v is offline   Reply With Quote
Old 09-18-2018, 08:51 PM   #4
travislambert
Drives: '17 ZL1
Are you sure all of the cooling ducts are in place? Something doesn't sound right...
Maybe the bleed didn't get all the DOT3 out?
Did you bleed both the inner and outer of each caliper?
Maybe different pads and Castol SRF?
travislambert is offline   Reply With Quote
Old 09-19-2018, 07:18 AM   #5
cdb95z28
cdb95z28's Avatar
Drives: 2022 1SS 1LE A10 BCD WCT+PDR
You're experience is the exception not the rule.
"KEEP THE FAITH"-Fbodfather
cdb95z28 is offline   Reply With Quote
Old 09-20-2018, 12:31 AM   #6
R3ctivision
1LE Convert
R3ctivision's Avatar
Drives: 2018 ZLE
I'm guessing you had some stickier tires than stock as well as the race brakes.
If that's true, you are asking a brake cooling system that was designed for stock tires and pads to handle race brakes and maybe slicks or something like a cup tire?
Not surprising they would fade. Either upgrade the brake cooling or go back to stock, the car should do just fine with proper brake burnishing.
R3ctivision is offline   Reply With Quote
Old 09-21-2018, 09:21 AM   #7
Osbornsm
Drives: 2018 SS 1LE
Tires are OEM Goodyear Supercar3
HP = Stock
Fluid = Motul RBF600
Pads = Raybestos ST-43
I upgraded the fluid and pads... thought those 2 things sorta go together.
Old 09-21-2018, 09:34 AM   #8
wildchevy
wildchevy's Avatar
Drives: 2018 Hyper Blue 2SS convertible
if you didn't disassemble the entire system and drain all the dot3 you have a bad mix of fluids.
2018 HBM 2SS CONVERTIBLE A8
wildchevy is offline   Reply With Quote
Old 09-21-2018, 09:38 AM   #9
cdb95z28
cdb95z28's Avatar
The Raybestos ST43 pads are the reason. I run them on my Gen 5 1LE. You cannot expect “stock like” brake temps when using full race pads. While the OEM air management does a fine job cooling the brake rotors, the calipers will still see the higher temps.
Old 09-21-2018, 09:49 AM   #10
GTSLOW
Daily Driven 1LE
GTSLOW's Avatar
Drives: 2018 1SS 1LE
This issue is certainly an operator head space and timing issue.
2018 1SS 1LE
GTSLOW is offline   Reply With Quote
Old 09-21-2018, 10:16 AM   #11
thescreensavers
thescreensavers's Avatar
Drives: SW 1SS 1LE / Jeep XJ
This is operator error, nothing to do with the car.
You need to manage your brakes. They will get hot and possibly boil fluid and or have pad overheating and that is something that you need to manage.
The brake pedal is not an on off switch.
I also recommend to use better brake fluid such as Endless RF-650 ,Castrol SRF, or Brembo HCT64
thescreensavers is offline   Reply With Quote
Old 09-21-2018, 12:08 PM   #12
cdb95z28
cdb95z28's Avatar
What track did this happen at?
Old 09-21-2018, 01:43 PM   #13
Osbornsm
Drives: 2018 SS 1LE
Autobahn Country Club - Full
3.56 mi
21 turns
Old 09-21-2018, 02:17 PM   #14
carguy55
carguy55's Avatar
No brake problems with stock pads and SRF and braking at COTA from 140+ mph, 5 sessions per day
carguy55 is offline   Reply With Quote
