#1 |
Thread Killer
Anyone run a separate oiling system for a blower or turbo-s?
They don't use allot of oil or need allot of PSI so it shouldn't cost a bunch ehy? Tips, directions? I could then run the blower on the high mile engine and not share oil, and need not to worry as thats the only chance of damage for the blower is sharing oil on a motor still goin strong but over 220,000miles. I can drive while the low mile one I got to build gets done right. Which means slow to afford the good stuff. If it won't kill me to run its own mini oiling system, I fear not. |
#2 | |
The tank must be located under the turbo or supercharger for proper drain back, and must be vented for expansion. The only issue is Pump Reliability, there are not that many good electric pumps you can rely on. I have changed a few turbos with a system like this when a bad ground caused the pump not to run and smoked the turbo. It only takes a few seconds without oil pressure and the turbo is JUNK. Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com |
#3 |
![]() ![]() ![]() ![]() Drives: 12 Boss 302 Join Date: Sep 2009
Most blowers I have seen have a seperate oil system(except for diesels). Most turbos run off of engine oil feeds. If you don't have an oil feed, you can buy adapter plates that go on the oil filter and have oil outlets off of the adapter. I have seen the electric pump setups, but usually in drag racing where the pump doesn't have to run for hours on end. I have never seen a system designed for daily driving.
#4 |
Thread Killer
Well yes Id have to add an oil feed line, but it has a built in drain back into the valley pan.
Its a matched blower/intake combo. But id like to run its own oil. Could just install a 4psi oil switch to the FP to catch oil loss. Any brand tips on who makes a good pump? |
#5 |
Thread Killer
Hey, brain fart.
Couldn't one just use a PS pump? Its a reliable setup. Id like to go manaul steer n e ways. |
| Vararam Ram air system for V-8 and V-6 2010 Camaro | sales@vararam.com | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 133 | 02-21-2013 09:25 PM |
| Anybody Spray'n their SS yet - nitrous ? | WeeZee | Forced Induction - V8 | 37 | 12-29-2012 09:56 PM |
| Nitrous System ?????s | PoleCat2SSRS2010 | Forced Induction - V8 | 29 | 12-08-2010 05:55 PM |
| Motorgen LA Invasion Videos (58) and Pics Thread | SeanPlunk | USA - California | 5 | 05-31-2009 01:23 AM |
| "Green" Car of the Year | Silverado | General Automotive + Other Cars Discussion | 17 | 11-28-2007 11:37 AM |
