#1 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: the 2nd amendment home Join Date: May 2008
Unusual Engines
... So Spike mentioned the other day he was watching Mad Max, and that got me talking with him about the supercharger clutch and if it would actually work or not.
This thread is for those unusual engine ideas you may have that you'd like to share... And yes, you can even talk about DEI as long as you finally understand IT JUST DON'T WORK LIKE THAT ![]() Anyone know what my avatar is?
-- Benjamin Franklin lib·er·ty /ˈlibərdē/ noun 1. the state of being free within society from oppressive restrictions imposed by authority on one's way of life, behavior, or political views |
#2 |
If you've never seen the movie, MAX had a clutch setup on his blower so he could turn it on and off. That's basically where we left off with our discussion, is it feasible?
#3 |
![]() ![]() ![]() ![]() Drives: 12 Boss 302 Join Date: Sep 2009
A clutched blower is possible, but in practice would probably be less effective as you would have to have enough clearance for air to get around the compressor when the blower was off. Your avatar looks like a constant pressure variable displacement hydraulic pump. Just a guess.
#4 | |
Link to my avatar if you'd like to know more about the amazing engineers of yesteryear. The Trebert Axial Engine http://www.dself.dsl.pipex.com/museu...g/axial-IC.htm
#5 |
![]() Drives: 2010 SS2/RS Victory Red Join Date: Jul 2009
Mercedes Benz Kompressors have a clutch.
#6 |
I suppose with intake runners like a Ford 3.8 uses, you could run a seperate inlet path with a blower. Since you only need the blower occasionaly, it could help reduce parasitic draw. With the clutch controlled by the MAP sensor, you wouldn't even need a switch.
#7 | |
Cool, I didn't know that. Bro's wife has the little roadster, I'll check it out next time I'm over
![]() How about seperate a/f tables in the ecu? Would it be necessary? If the blower was always switched at a certain load, I would think it could be tuned, but the switch idea probably complicates things.
#8 |
Run a MAP for blower on and off, and MAF for A/F. And yes, it would have to have a switch to overide the MAP. An engineer once told me that the auto/sport switch on auto suspensions was put in not for functionality, but because the focus group guys wanted it.
#9 |
#10 | |
#11 |
![]() Drives: 5.4 3v Join Date: May 2009
New GT500's come with the supercharger off from the factory. It is tuned to dump any boost out the bypass until the new owner puts a number of miles on it or a couple consecutive starts.
#12 |
#13 | |
#14 | ||
![]() ![]() Quote:
I can see how this setup would work great on a marine application with a planing hull... Use the torque to get it on plane, then kick off the compressor to cruise.
| GM cars could get BMW engines | Tran | General Automotive + Other Cars Discussion | 36 | 11-12-2009 10:00 AM |
| Perceptions Die... OK Say Again Y Foreign is Better | Cmicasa the Great XvX | General Automotive + Other Cars Discussion | 428 | 11-09-2009 04:04 PM |
| Victory Racing Engines, Clinton TWP Michigan | DetroitMuscle2010 | USA - Great Lakes | 9 | 09-21-2009 06:03 AM |
| Gas engines: Here to stay | Mr. Wyndham | General Automotive + Other Cars Discussion | 0 | 05-05-2008 03:34 PM |
| GM takes two spots in WARDS 10 Best Engines | Scotsman | General Automotive + Other Cars Discussion | 10 | 12-14-2007 08:02 PM |
