07-12-2018, 03:12 PM | #1 |
Drives: 2010 SS/RS M6 Join Date: Oct 2017
Nitrous - HP gain VS Shot size
Hi Guys & Gals, first post here. Have had my Camaro for a little over a year & a 1/2, have been lurking on this forum since the day I bought the car. Have learned a TON of info from this forum, all mods I have done I researched here first.
Question: Car is at the Dyno today (I'm at work) & the tuner just called me asking if I was positive I'm running a 100 shot (I am). He said we are seeing almost 155 rwhp/rwtq increase with the Nitrous! Has anyone else seen such a difference in HP VS shot size? Will post actual numbers after I pick up the car & get Dyno sheet. Thanks, Jim Edit: Just got back from picking up the car. He pulled quite a bit of timing from original tune (8 degrees) lost 34 HP/41TQ. Now it sits at 370rwhp/366rwtq on the 100 shot it makes 561rwhp/569rwtq, so a 191hp/203tq gain on a 100 shot. Base run today was down 3 HP due to weather conditions from original tuning. AFR is 12.3 N/A & 11.5 - 12.00 on nitrous, running 92 octane with a bottle of torqo added. Timing was 22 degrees now at 14 degrees.
K & N CAI, Vmax PTB, Moroso CC, MSD Blaster Coils/8.5 MSD Plug Wires, Kooks LTH W/ HF Cats, Custom exhaust system W/ Noweeds Cutouts, Upgrade bushing kit for Hurst shifter, Hurst Line Lock, DSS Stage 4 Axles, DSS one piece CF Drive Shaft, Custom Built 1000 HP Clutch, BMR Drag Package/Toe Rods/Coil Over Conversion etc., BMR Extreme rear sway bar, BMR Sub frame connectors, BMR trans tunnel brace, BMR DS safety loop, Nitrous Outlet wet system W/100 shot, Nitto 315 DR's for strip, 315's for dd, Dyno tuned at 406rwhp/407rwtq N/A, 561/569 on Nitrous.
07-12-2018, 04:32 PM | #2 |
Drives: 2013 1SS 1LE Join Date: Jun 2016
I put in "75" jets and got 100hp on the dyno. I think it depends alot on the set up (cam, heads, intake).
603 h.p. 495 ft lbs tq. |
07-12-2018, 06:06 PM | #3 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
Yikes! That's a heck of a shot
07-13-2018, 12:36 AM | #4 |
I know right? Just got the system dialed in today...the #'s quoted are straight off the dyno sheets, base run, timing retard run, then nitrous pull...I was shocked at the #'s as well...A lot more than I expected from a 100 shot & conservative tune, can still put more timing back in, most likely won't this year, I like the safety net of the tune. BTW Dynojet dyno if that matters to anybody, but car was bone stock when I started & this is the only dyno it's been on, so #'s for comparison purposes for my car should be realistic?
07-14-2018, 10:40 PM | #5 |
GrINned & JUICEd
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1 Join Date: Nov 2009
N.O. recommended jetting is for rear wheel hp. That seems a bit much. Double check jets. 52N 28F.
Maybe stamped wrong? Is the shop adjusting the duty cycle of the injectors or adjusting fuel jet. My 2010 stock fuel system would not support that amount. After the initial hit, fuel pressure recovery was way too slow.
07-15-2018, 12:42 AM | #6 | |
07-15-2018, 02:03 PM | #7 |
Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
this is why nitrous guys refer to jet size instead of "shot size". there isn't always a direct correlation between the two. if your tune is good, leave it be and run it, you'll be fine
07-15-2018, 09:30 PM | #8 |
Drives: Camaro and Sierra Join Date: Jul 2012
Put 200 pills in and picked up just over 200 hp and tq
07-16-2018, 03:33 AM | #9 |
thanks for the info...tune is super safe will run it as is next weekend
07-16-2018, 02:20 PM | #10 |
GrINned & JUICEd
What's the bottle pressure?
07-16-2018, 02:54 PM | #11 |
bottle was full approx. 950 ish w/o heater on. that was early am...I'm sure it was around 1100 or so by the time they were tuning, it's been hot as hell here lately.
