Go Back   Chevrolet Corvette Stingray C7 Forum > Members Area > Past Camaro Fests > 2018 Camaro Fest (VIII)
Old 07-10-2018, 10:42 PM   #1
Moeman
THE Cone Killer
Moeman's Avatar
Drives: 2015 2SS/RS BVM; 2016 Vette Z51
Directions to CF8 from I 40 west coming from Knoxville.
Looking for the best route to get to CF VIII coming from I40 from Knoxville,
Is it best to go all the way to Nashville and north on 65 OR get off on one of the twisty curvy roads ? Thanks for responding.
ARH Full exhaust w/ HF cats
CAI Cold Air Intake w/ scoop,
Gears 3.73
BMR 1.25 inch lowering springs, Trailing Arms, Toe Links, Cradle and offset Diff Bushings,
Bilstein Struts, front and rear
ZL1 rear Diffuser, Rocker Panels, 1LE Front Splitter
Z28 High Wing Rear Spoiler,
Tuned by DynoSteve
Moeman is offline   Reply With Quote
Old 07-10-2018, 11:32 PM   #2
RubyCamaro
Jan
RubyCamaro's Avatar
I guess it depends on if you want a fun drive or a quick one.
Old 07-11-2018, 05:46 AM   #3
Bertha II
Bertha II's Avatar
Drives: 2010 2SS/RS M6 SW
I-40 West to Nashville, North on Briley Parkway and then north on I-65 to BG is the quickest way. Hwy 109 and Hwy 231 routes are a few miles shorter but not as quick.
TSP Stage 3 Cam, BBK SS/Ceramic Headers, Solo Cats, Borla Exhaust/Deletes, K&N CAI, Lethal Performance Tune, Carbotech Brakes, Phastek Braided Brake Lines, Brake Ducts, BMR/Eibach Springs, Hotchkis Sway Bars & End Links, BMR Chassis Connectors, Vorshlag Camber Plates, 1LE 3.91 Gear, Hurst Shifter, 2017 ZL1 Wheels, ZL1 Grille and Ground Effects, SLP Splitter, MPD1 Spoiler, Oracle Interior Lighting, Gen5DIY Headlight/Halo/DRL System
Bertha II is offline   Reply With Quote
Old 07-11-2018, 04:10 PM   #4
laynlo15
Drives: 2022 Lt1 A10
Garmin or Google will give you the best route. I use my Garmin.
Old 07-11-2018, 08:50 PM   #5
rwi2112
Green Manalishi
rwi2112's Avatar
Drives: 2010 Synergy Green Camaro LT
When we came back from Pigeon Forge to Indiana Via BG, we went toward Lexington then cut over at London. Not sure of the time difference if you go that way.
rwi2112 is offline   Reply With Quote
Old 07-11-2018, 10:10 PM   #6
nearwater
nearwater's Avatar
Drives: '17 2SS 50th
I drive to Knoxville almost every weekends from BG and whichever route you take, it doesn't make that much of a difference.
Always about 2:45 to 3:00 drive depending on traffic.
On busier weekends, I recommend taking 231 as it seems to have less construction going on.
'17 2SS 50th Anniversary | M6 | MRC | NPP | Nav | Sunroof | Black bowtie | GM dark tail
nearwater is offline   Reply With Quote
Old 07-12-2018, 01:37 AM   #7
Tenfive
Tenfive's Avatar
Drives: 2017 1SS camaro ,2SS a 68 + 08 C6
Im in knoxville now
Gotta make a run at deals gap and run the dragon
Then pick up big. Jon amd head in to Bg
Tenfive is offline   Reply With Quote
