05-14-2018, 08:43 PM | #1 |
Drives: 2017 camaro SS Magnuson Heartbeat Join Date: May 2018
No meth need it.....600whp magnuson heartbeat
Hi guys , Im new to this thread and forum but old in the chevy camaro clientele.
I just want to share with you guys my last expirience with my new build. I have a 207 camaro ss with a magnuson hearbeat 87mm pulley, rotofab and kooks headers , v max ported throttle and Fuel control moduel re programmed by my friend and tuner at Lingenfelter in Michigan....all this with 100oct. I went to dyno this past saturday and in my first pass i made 611whp and a second pass of 610whp with 533tq. I live in PR and my tuner is in Michigan, so im super astonish of the results as I know is more difficult to tune remotely than it is live at the dyno..... here is my dyno sheet and a little video, test was performed in STD not SAE. This week ill be installing new pulley and low side pump and HPFP, so lets see was comming next |
05-15-2018, 07:49 PM | #2 |
Drives: 2018 SS 1LE Join Date: Apr 2017
Welcome to the forum. Stay off the meth.
05-15-2018, 08:37 PM | #3 |
Drives: 2014 Red Hot LS3 Join Date: Oct 2014
05-16-2018, 09:57 AM | #4 |
Hahaha, just notice that.... Meth
Thanks for the welcome✌ |
05-16-2018, 01:50 PM | #5 |
Drives: '17 Camaro 2SS & '99 Camaro Z28 Join Date: Feb 2014
Do you always have to use 100 octane?
05-16-2018, 08:11 PM | #6 |
Yes,.... i could use 93oct but it will not be safe to go around racing, but good for daily driven.
My tuner is in the process to fabricate me a "switch" like the ones I had in my other camaro when using NOS, that change you the timming so I can use 93oct safely even at WOT. Im not gonna stay like this, this was just a test because I was desperate to know what we could do with 100oct and with only the magnuson, originally i had 421whp NA with nothing, not even a tunne (secondary cats were removed)... I have ZL1 low side pump and LT4 HPFP that will be installed newt week. |
05-16-2018, 08:49 PM | #7 |
Great numbers, I've been running Maggies for sometime now. You can look at my numbers and ets and realize where you can go with just a fuel system, pulley and better fuel plus a little meth if you want.
600whp, camaro gen 6, camaro ss 2017, magnuson heartbeat |
