11-13-2017, 09:18 PM | #1 |
Drives: 2017 SS 1LE Join Date: Aug 2017
RE71Rs for the front and RE11s on the rear
Hey guys, wondering if anyone has attempted or has some good knowledge on why or why not to run 2 different brands for autocross. Im looking at doing 305/19 RE 71Rs on the front of my 1LE and 325/19s RE 11s on the rear.
11-13-2017, 09:30 PM | #2 |
Drives: Cayman S or Borrowed 17 1SS 1LE Join Date: Apr 2017
Bad idea mix matching those two tires because of the difference in grip. Run the 305/30/19 71r all around
11-13-2017, 09:32 PM | #3 |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
You'll have more grip with 305 RE71R's on the back than you will with any width RE11. That's why the RE11's were replaced by the RE71R's.
11-13-2017, 09:39 PM | #4 | |
I used to be Dragoneye...
What are you hoping to achieve? |
11-13-2017, 10:18 PM | #5 | |
Ok this is what i was wondering. 305s were my original plan, but saw these 325 re11s and were pretty tempted |
11-13-2017, 10:30 PM | #6 |
@zle_blackwing
Drives: 2018 ZL1 1LE Join Date: Mar 2017
I’ve had both and the RE71Rs are head and shoulders above the RE11s. I wouldn’t do it just based on size.
2018 ZL1 1LE - Red Hot, Nav, PDR
11-14-2017, 07:14 AM | #7 | |
Different tires could make the car unpredictable. |
11-14-2017, 07:40 AM | #8 |
corner barstool sitter
Attempting to solve an understeer problem by playing games with the basic front vs rear slip angle curves is not only risky; it can hurt you in other places (if the rear insists on being a lot looser the car can get "out of step with itself", typically in slaloms).
I've seen an extreme example of what you're suggesting . . . and it flat-out should not have been permitted to pass tech inspection. Norm
11-14-2017, 09:15 AM | #9 | |
Hot Dog
Let's start with the obvious: what's your alignment? If you're not at a minimum at the Performance Supplement "track" alignment, then you're behind the 8-ball. Even then, tire wear on this platform is proving to be shoulder-heavy even with neutral balance.
11-14-2017, 09:41 AM | #10 |
Drives: 2017 Hyper Blue A10 ZL1 Join Date: Dec 2016
I was getting outside tire wear as well, but the regular ZL1 cannot get as much negative camber as you can without non-stock components. You probably need more.
The car shouldn't plow if you are not bombing into to the corners. I also would think alignment. I had one car that I got brand new that just didn't have non-optimal configurations for racing, but had different camber, toe, etc on every wheel. It was a hot mess until I got it fixed up for racing. I wondered how they could ship it like that, but....
- Life is a highway... I want to ride it all night long...
Sold 2010 997 GT3, 2016 WRX, 2006 997 C2S, 2003 996 C4S, 2001 Boxster S, 1997 E420 AMG etc.. |
11-14-2017, 09:41 AM | #11 |
Drives: ZL1 1LE Join Date: Sep 2017
I've mixed tires once without any ill affect but would not do it as a rule. The RE11 and RE71R are probably different enough that I would not recommend it.
11-14-2017, 10:02 AM | #12 | |
"M1SS1LE"
Drives: 2017 SS 1LE Join Date: Dec 2015
MJK3888 Instagram Link
11-14-2017, 10:48 AM | #13 |
Drives: 22 1SS 1LE Summit White Join Date: Sep 2016
yeah there are so many other things you can do before changing tires front to rear.
Having different tires from front to back in theory would work like youre thinking but people have tried it with little success. I played around with tire sizes and that seemed to help me with turn in.
#53 F Street
2022 Sponsor autocrossdigits.com Autocrossing Videos https://www.youtube.com/channel/UCm-...3tiMt0KOg_2Aag Instagram: apexit_53 2022 Rapid Blue 1SS 1LE 2019 D Street national champion (2019 civic Type R) |
11-14-2017, 01:59 PM | #14 |
Drives: 71 Camaro '18 1LE Join Date: Feb 2016
OP, are you new to autocross?
Where does the car push? On entry, mid corner, or on exit?
Donny
