11-11-2017, 08:36 PM | #1 |
Drives: 2011 Camaro 2SS L99 Join Date: Oct 2016
speed limiter
okay so i bought my camaro used and i’m guessing a previous owner tampered with the limiter it says “speed limited to 75 mph”. how can i reset this to stock?
11-13-2017, 02:27 PM | #2 |
Drives: 2014 2ss/rs Join Date: May 2012
Speed limiter in the ECU, or speed warning in the DIC?
one is programmed into the ECU and prevents the car from going faster than that period, no iff's and's or but's. the other merely beeps when you pass the speed indicated. |
11-13-2017, 08:24 PM | #3 |
it is limited so it will not go over the set speed
11-13-2017, 08:27 PM | #4 |
Drives: 2013 1SS 1LE Join Date: Jun 2016
Did you look in your manual?
603 h.p. 495 ft lbs tq. |
11-17-2017, 12:31 PM | #5 |
no, i did not think it would be that simple, but i will try that.
11-17-2017, 01:13 PM | #6 |
7 year Cancer Survivor!
Drives: 17 Cruze RS, 07 G6 GT, 99 Astro Join Date: Dec 2007
Was it a former rental car? Maybe the rental agency had the speed limiter set. I just read where some rental agencies are doing that.
The Bird is the word! Last edited by Angrybird 12; 11-17-2017 at 02:02 PM. |
11-17-2017, 01:59 PM | #7 |
I just checked the manual and there is only info about the Speed Warning, nothing about setting a limiter or any message on the DIC about “speed limited to 75mph”.
The Bird is the word! |
11-17-2017, 02:04 PM | #8 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
If it truly is limited, and not just the warning on the dashboard, I would give your local dealership a call and see if they can do a flash for you.
Otherwise, I would just get a proper tune from a vendor on here.
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
