Old 10-23-2017, 01:20 PM   #1
WILWAXU
WILWAXU's Avatar
Drives: 2019 Crush ZL1 1LE
Thumbs up Ford to build a "1LE" like 2018 Mustang
http://www.motortrend.com/news/2018-...t-look-review/
Originally Posted by MotorTrend
Mustang engineers work nights to counter the Camaro 1LE
If you passionately love what you do, you’d work for free. That’s the old adage, and that’s apparently what a bunch of Ford Mustang engineers did in order to develop their dream Mustang chassis/handling package. These track enthusiasts had a vision of their ideal Mustang that went beyond the Performance package that got baked into the initial 2018 Mustang order book. Rather than ask permission and risk being shot down, this internal skunkworks toiled nights and weekends developing the parts needed to achieve their own aggressive targets. As soon as the package suited them, they presented the results to their bosses, and voila! Now we can all enjoy an even more extreme Performance package variant for the 2018 Mustang GT dubbed simply “Level 2.”
First, a refresher on the preapproved Performance package. For $3,995, the GT Performance package adds: 9.0-by-19 front and 9.5-by-19-inch rear black wheels wrapped in 255/40R19 and 275/40R19 summer tires, respectively, Brembo six-piston front brake calipers with larger rotors, oil pressure, and vacuum gauges, heavy-duty front springs, a stiffer rear anti-roll bar, an underbody K-brace, a larger radiator, performance rear wing (fastbacks) or spoiler delete (convertibles), silver-painted strut-tower brace, Torsen differential with 3.73:1 axle ratio (manual) or 3.55:1 axle ratio (automatic—sorry, Level 2 is available only with the manual) and unique tuning of the chassis/electric power steering/ABS/stability-control systems, and Magneride adjustable dampers. You know, like the ones used on various Ferraris, Corvettes, and the Camaro SS 1LE package. Think of Ford’s base Perf Pack as roughly equivalent to a Camaro SS ordered with the 1LE handling and Magnetic Ride packages, which together cost $3,665.
Perf Pack Level 2 is a $6,500 package available only on Mustang GT fastback manual cars. If ordered on a base GT, you must also opt for the $2,000 Equipment Group 301A—dual climate control and Sync 3 AM/FM/CD, and for comparison purposes against Chevy’s full-on $7,000 1LE Track Performance package, you might as well know that Level 2 lacks the 1LE’s head-up display, and Ford charges $895 for its performance exhaust that Chevy throws in.
Level 2 aims to counter the dynamic capabilities of the 1LE Track Pack. To do so, the skunkworkers took a holistic approach to enhancing mechanical grip and aerodynamic downforce. For starters, there’s a good bit more rubber meeting the road: The tire cross section is increased considerably by fitting 305/30R19 meats all around, mounted to staggered-fitment wheels that are 10.5 inches wide in front and 11.0 inches in back. Oh, and naturally they’re not just any old tires—they’re Michelin Pilot Sport Cup 2s (Camaro SS 1LEs we’ve tested ran Goodyear Eagle F1 Supercar 3 tires, 285/30R20s front, 305/30R20s rear).
Working our way up, relative to the already stiffened Perf Pack springs, the Level 2 coils are 20 percent stiffer in front and 13 percent stiffer in the rear. Similarly, the anti-roll bars resist twist by an additional 12 percent in front and 67 percent in the rear. Oh, and between the lower-profile tires and suspension tweaks, the car hunkers down a half-inch closer to the road. Some of the midnight oil burning involved further tweaking of the Magneride shocks, electric steering assist, ABS, and stability control tuning.
The aero work started off with a modified Boss 302 Laguna Seca front splitter that extends about 3 inches out from the front corners, developing 24 pounds of honest-ta-goodness front downforce at fast-sweeper speeds (80 mph). Balancing this out is a subtly redesigned rear spoiler that was designed by a process of successive track tests with different designs that had been 3-D printed.
The end result is said to roughly split the track performance difference between the GT Perf Pack and the mighty GT350, delivering lightning-quick responsiveness and seemingly endless braking and cornering grip. You’ll be able to spot a Performance Pack Level 2 car by its unique 10-spoke “Dark Tarnish” wheels, black spoiler and splitter, and tire spats on the back of the rear wheel openings.
So which one should you bet on the first time these two titans clash? The new Mustang V-8 is tuned to shade the Camaro by 5 hp, but the bigger-lunged Chevy out-torques the Mustang by 35 lb-ft, and they run similar gearing, so expect the Chevy to out-drag the Mustang on the straights. In the corners? Sadly we have no comparative numbers for this generation Mustang GT on a track where we’ve also run a Camaro SS 1LE, and GT350. The best we can do is look at three Mazda Raceway Laguna Seca best-laps set by Randy Pobst, who ran a Boss 302 Laguna Seca edition (444 hp/380 lb-ft) setting a best time of 1:41.06, while the SS 1LE did 1:37.77 and a GT350R ran a 1:36.11. That suggests that the Perf Pack Level 2 needs to bridge 2/3 of the gap between that lower-output (but similarly track-optimized) Boss 302 and the current GT350 in order to match the Chevy. It’s gonna be an interesting battle for sure! Cars are orderable now with deliveries expected in Spring 2018.
John Brown
Instagram @wilwaxu
Facebook @wilwaxu
WILWAXU is offline   Reply With Quote
Old 10-23-2017, 02:27 PM   #2
detltu
detltu's Avatar
Drives: 1992 Z28 1LE; 2015 Zl1
Very nice.
Seems like they like to throw around the "worked in secret" stuff all the time. I'm not buying it. Very cool package though and should help bridge the gap between the GT and 1LE.
1989 Camaro RS convertible- Sold
1999 Camaro SS - Stolen 2x
1991 Camaro Z28-
1991 Camaro Z28 1LE-
1992 Camaro Z28 1LE- 25th anniversary
2015 Camaro ZL1
detltu is offline   Reply With Quote
Old 10-23-2017, 03:11 PM   #3
ssrs2lt
ssrs2lt's Avatar
Drives: too many
Not surprised
Old 10-23-2017, 03:33 PM   #4
motorhead
Looks great! Should perform well
Old 10-23-2017, 03:35 PM   #5
xc_SS/RS
Drives: 2010 Camaro SS/RS
Nearly 4 seconds is a lot around Laguna Seca... I'll be keeping an eye out for the review of this.
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 10-23-2017, 04:06 PM   #6
SSEssence
Instagram: Sangstah
Drives: 2019 Camaro 1LE
Awesome of them to step up to the plate, the package looks good!
SSEssence is offline   Reply With Quote
Old 10-23-2017, 04:13 PM   #7
Stormcloak
slower than you
Stormcloak's Avatar
Drives: 2012 C6 Z06
Good. This is what the PP should have been right from the start, really. Redesign that half-faux front grill work, and you'll have a proper car going.
/patiently waits for Ford to say these are 'limited quantity' packages so dealers can continue the ADM game.
Stormcloak is offline   Reply With Quote
Old 10-24-2017, 07:29 AM   #8
Expunge
Expunge's Avatar
Drives: 2013 ZL1 M6, '99 Tahoe 2Dr Sport
Meh..
Expunge is offline   Reply With Quote
Old 10-24-2017, 08:53 PM   #9
hotlap
hotlap's Avatar
So much for the "holistic approach" to "counter the dynamic capabilities of the 1LE Track Pack". After the GT350 overheating debacle? What a joke.
Note: For track day use with Performance Pack Level 2, we recommend that you add aftermarket transmission and differential coolers. Your vehicle is equipped with electronic controls that, if required, reduces power and limits RPM in order to control powertrain temperatures.
http://www.fordservicecontent.com/Fo...gEnabled=False
Ronald Reagan -
Old 10-24-2017, 09:02 PM   #10
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
Yeah... that's really lame
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 10-24-2017, 09:52 PM   #11
Bhobbs
Bhobbs's Avatar
Haha what a joke. They don't bother to put coolers on the base PP or even the upgraded PP? Why bother with the 305 Cup 2s if the car can't use them?
Old 10-25-2017, 09:47 AM   #12
detltu
detltu's Avatar
The cooler language is really disappointing. GT350 all over again.
1991 Camaro Z28-
2015 Camaro ZL1
Old 10-25-2017, 11:04 AM   #13
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Wow, complete fail AGIAN.
Track car you can't track.
Old 10-25-2017, 03:08 PM   #14
JerTM
JerTM's Avatar
Drives: 2011 2SS/RS M6
Sounds like Ford doesn't want to put their money where their mouth is. You can't track the car without the cooler package, the cooler package most likely voids the warranty.
JerTM is offline   Reply With Quote
