#1 |
Not camaro related but ls question
Ok so I'm helping a friend put a 5.3 truck engine in his 74 Stingray. Car has the factory th400 in it. What do I need to adapt the engine and trans together?
https://www.instagram.com/whoopa_ss/ |
#2 |
![]() Drives: 2010 Camaro SS 2SS Join Date: Jul 2017
A foundry
#3 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 CGM 2SS/RS LS3 Swapped A6 Join Date: Sep 2016
New flexplate, crank spacer. Fairly certain it will bolt up, although you may have a couple unused bolt holes.
There is certainly more to this, but that's what I know of. I think Bo White is running a TH400 in his Camaro, so maybe PM him?
#4 |
![]() Drives: 2017 1SS auto vert Nightfall Gray Join Date: Jan 2017
I have a 5.3L in my 2004 Silverado and love it. 150k miles and no problems. The show Iron Resurrection just put a used 5.3 and matching trans in an old Metro van. Not sure why you drop in a plant that doesn’t marry up to your trans. Good luck!
Sent from my iPhone using Tapatalk |
#5 |
![]() Drives: 2015 Z/28, 2015 1LE Join Date: Feb 2017
contact advanced adapters. they will hook it up. heard this on a daily at summit racing
#6 | |
Captain Gingerbeard
Drives: 2012 IOM RS/SS 6MT Join Date: Feb 2013
You're either looking at an adapter kit like mentioned above, or you get a TH400 that's designed to bolt up to an LS-style block.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads. Quote:
#7 |
![]() Drives: 2018 Hyper Blue 2SS convertible Join Date: Aug 2017
I did a google search a search with your question here is the first result.
http://www.advanceadapters.com/produ...flexplate-kit/
2018 HBM 2SS CONVERTIBLE A8 |
