Old 10-14-2017, 07:01 PM   #1
RiCorvette
RiCorvette's Avatar
Drives: 2017 Corvette Grand Sport 3LT
Used 17 GS - poor fuel economy
Is there a fuse pull trick to reset the ECU on a 2017 Grand Sport Automatic, like pulling #5 and #20 on the Gen 5 Camaro?
If so, which fuse(s) or just disconnect the Battery?
Not sure if regular gas was used for the 'complimentary' fill up upon vehicle purchase from a (non GM) dealer, causing such poor fuel economy, but i'm getting only 9.7 mpg in mixed highway/city driving.
Or should I be looking for other problems (beside PbPeditis)?
RiCorvette is offline
Old 10-15-2017, 07:40 PM   #2
h422694
h422694's Avatar
I had a C6 LS3 that got 15-16 around town on 87 octane and 30+ on the road using 91 octane. I only used 91 on road trips. I now have C7 Z06 and only use 91 octane that gets 13-15 in town and an easy 27.5 on road. I'm pretty sure there is a way to reset the map back to original and it is not done via fuses. I thought I read an article that indicated the ECM recognized the difference in gas and used the corresponding fuel map but could be wrong. Someone on here should know. Until then, I'd start looking at other possibilities.
h422694 is offline
Old 10-29-2017, 12:27 AM   #3
REVVIC
Drives: 2014 Z51 Velocity Yellow
If you have run through the complimentary fill up and at least one tank of premium with mpg data at circa 15 local and 30 highway, you're on track. If not, take your GS to a reputable Chevy dealer.
REVVIC is offline
