Old 09-25-2017, 06:41 PM   #1
Unsterblich
Drives: 2012 Camaro RS convertible
Key fob/ key
When I bought my 2012 RS, I received a regular key along with The old fob because the previous owner snapped the key off of the fob. The fob works. But I'd like to have a new one that doesn't have a broken key on it. I know how much the fobs are. Does anyone know if the fob/key is programmed easily? Or is it a programming that requires the dealer scan tool?
Unsterblich is offline   Reply With Quote
Old 09-25-2017, 06:47 PM   #2
Eddiefuzz
Eddiefuzz's Avatar
Drives: 2011 RS
You can get a FOB on AMAZON for about $20. You just turn the key to the start position a few times then start the car. The dash will say 3 keys programmed. You can tap the pin out of the old key and the blank key and put the old key into the new FOB and tap the pin back in and you're all set.
Eddiefuzz is offline   Reply With Quote
Old 09-25-2017, 06:52 PM   #3
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
Possible it wasn’t snapped off by the previous owner but was removed due to the key recall. You can but replacement fobs online but will need to get the new key laser cut to match the existing key. I think the programming sequence is in the owners manual as long as you have a working fob.
The Bird is the word!
Old 09-25-2017, 07:16 PM   #4
PeteD
PeteD's Avatar
Drives: 2012 2SS Victory Red with white st
I bought an extra key for mine. I had the recall key. When I bought it (from my local chevy dealer) it was actually the switchblade key. Yay! Seems like each year has a specific method
Mine is a 2012 2SS and it is as simple as this
PeteD is offline   Reply With Quote
Old 09-12-2018, 12:07 PM   #5
nickbettschen
Drives: 2020 Camaro 2SS Convertible
where did u get the insert
nickbettschen is offline   Reply With Quote
Old 09-12-2018, 05:30 PM   #6
PeteD
PeteD's Avatar
Hey there....you get it from your local Chevy dealer. After the recall they sent out a TSB and you will get them for free.
