Old 11-03-2009, 07:31 PM   #1
boxmonkeyracing
juggernaut
boxmonkeyracing's Avatar
Drives: VRSCF, 2011 SS vert
Send a message via AIM to boxmonkeyracing Send a message via Yahoo to boxmonkeyracing
help box lose weight
need to lose 40 lbs and I'm keeping track on bodybuilding.com
We do not want to use the Z28 moniker on a car that does not deserve this hallowed name.
boxmonkeyracing is offline   Reply With Quote
Old 11-03-2009, 07:33 PM   #2
BackinBlackSS/RS
Go Blue!!!!!
BackinBlackSS/RS's Avatar
Drives: 2012 Cruze LT
It's as simple as calories in vs calories out. Get your exercise too!!!
Old 11-03-2009, 07:35 PM   #3
boxmonkeyracing
juggernaut
if you stop eating (already eating healthy) then your body burns less and stores more. issue I have.
Old 11-03-2009, 07:37 PM   #4
thecamaroguy
thecamaroguy's Avatar
Drives: 2020 ZLE 67 SS350
P90X...it's amazing!
Thanks,
thecamaroguy
2010 Camaro 2SS - CGM
1967 Camaro SS350 - Baldwin Motion Tribute
2020 Camaro ZL1 1LE - White
Proud to say I have always owned a Camaro! A Camaro has been my Daily driver since I started driving!
thecamaroguy is offline   Reply With Quote
Old 11-03-2009, 07:40 PM   #5
1320junkie
Drives: The Imperial Army
Old 11-03-2009, 07:44 PM   #6
boxmonkeyracing
juggernaut
HIIT seems to be working.
Old 11-03-2009, 07:49 PM   #7
BackinBlackSS/RS
Go Blue!!!!!
I didn't mean stop eating. You need to find the calorie level that maintains your weight and then set your level below that. Weight Watchers has a great system for figuring out your daily intake. They use a point system. My wife and I have been very successful with it. Bottom line is if your not losing weight your eating too much. There is no getting around this.
Old 11-03-2009, 07:52 PM   #8
boxmonkeyracing
juggernaut
I'm slowly losing the weight, which is fine since I'm building muscle at the same time. BUT I want to lose more weight while building muscle. it's becoming a hard balancing act right now on the over all goal to be down to 180 in the next 4 months. current weight is 217.
Old 11-03-2009, 08:30 PM   #9
BackinBlackSS/RS
Go Blue!!!!!
Sounds like your on the right track. Be patient, you will get there.
Old 11-03-2009, 08:54 PM   #10
nUcLeArEnVoY
Oldbie that nobody knows
nUcLeArEnVoY's Avatar
Drives: 2011 1SS/RS M6
Send a message via AIM to nUcLeArEnVoY
The key to dieting is consistency, because then when you plateau, it's easier to adjust it to fix the problem. When you think it's because you need to do more cardio, it's probably because you just need to binge on a bunch of carbs to restore leptin levels. BB.com is an okay place to be and research is always your best friend.
nUcLeArEnVoY is offline   Reply With Quote
Weight reduction on camaro? LDGn63 5th Gen Camaro SS LS LT General Discussions 201 02-11-2013 09:13 PM
New Brembo Brake Upgrade for 2010+ Chevrolet Camaro SS CarNutzCustomz Wheels and Tires Talk Sponsored by The Tire Rack 42 12-22-2011 05:58 PM
ANYONE WANNA START EXCERCISING/LOSING WEIGHT WITH ME? Matrix Off-topic Discussions 143 10-19-2010 04:51 AM
Great deal on 2-piece rotors Doc Suspension / Chassis / Brakes 90 11-28-2009 09:53 AM
weight loss CamaroSpike23 Off-topic Discussions 8 09-17-2009 08:16 PM
