Roto-Fab
Old 08-04-2017, 12:42 PM   #1
TrevinE
TrevinE's Avatar
Drives: 1967 Camaro RestoMod
Which Lowering springs with 18s?
just got the vert converted to 18" race stars and i want to start thinking about lowering springs. I have MT ET Street R 18" 305/45 on the rear with 255/55 18s on the front.
For those that have similar set ups, what amount of drop are you using and which ones. I think the OD of the new set up is really close to the stock 20" OD but want to make sure.
Thanks
1967 Camaro Resto Mod. 468 roller. Tremec TKO600, 2011 Imperial Blue Metallic paint, full Hotchkis suspension, Wilwood disc brakes, Ron Davis radiator, Comp Cam, Custom aluminum air intake, custom valve covers, Rushforth rims, ET street radial IIs
TrevinE is offline   Reply With Quote
Old 08-05-2017, 09:57 AM   #2
Btrbimmer
Drives: 2SS 1LE Silver w/Recaro NPP
Are you setting up the car for the drag strip?
Do you use it as a DD?
What are you looking to accomplish?
-BtrBimmer
'14 2SS 1LE NPP Recaros
Btrbimmer is offline   Reply With Quote
Old 08-05-2017, 11:37 AM   #3
TrevinE
TrevinE's Avatar
It's not a DD mostly just street weekend fun and drag every now and then. Should be close to 900whp when done so definitely want traction help.
Ideas?
Old 08-06-2017, 06:45 AM   #4
Btrbimmer
BMR should be a good starting point. I'm not in tune with drag racing type suspensions.
Ideas?
-BtrBimmer
