Old 07-27-2017, 10:13 PM   #1
jrhagen
Drives: Camaro
Do you math?
Simple question, can anybody answer it, correctly?
36/2(3)=?
There are 2 common answers, only one is correct.
jrhagen is offline   Reply With Quote
Old 07-27-2017, 10:15 PM   #2
SynergyGreenSS
SynergyGreenSS's Avatar
Drives: 2011 2SS
Is it 6
2011 SS L99
LSA Supercharger, BTR Stage 3 PDS Cam, Yank 3200SS, Weapon X Stage 2 intake, LSA Heads, Flex Fuel, Ported throttle body, Speed Engineering Headers, NOWEEDS, ZL1 fuel pump, DSX AUX Pump, ID-1050X injectors, 3” pipe to NPP mufflers, 3.91 gears
SynergyGreenSS is offline   Reply With Quote
Old 07-27-2017, 10:16 PM   #3
54 I think.
Old 07-27-2017, 10:18 PM   #4
SynergyGreenSS
Drives: 2011 2SS
I'm thinking it's 6 because of pemdas. Parentheses, exponents, multiplication, division, addition, subtraction. So you do multiplication first: 2 x 3 = 6. Then you do division: 36/6=6
2011 SS L99
Old 07-27-2017, 10:20 PM   #5
jrhagen
Drives: Camaro
I'll give you a hint multiplication and division are equals and done left to right.
Old 07-27-2017, 10:25 PM   #6
But the parenthesis used here aren't to indicate order of operations, it's there to indicate multiplication.
If it was 36/(2+3) then it'd be a different story.
Old 07-27-2017, 10:25 PM   #7
chuckie669
chuckie669's Avatar
Drives: 2011 ss
You would do the logic within the parenthesis first. It's already solved. Go left to right
chuckie669 is offline   Reply With Quote
Old 07-27-2017, 10:32 PM   #8
The_Blur
Moderator
The_Blur's Avatar
It's 54.
warn 145:159 ban
Old 07-27-2017, 10:53 PM   #9
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
I do math. My differential equations teacher in collage was fired when I showed up.
Edit: Well not really fired, he was retired.
Bunch of worthless shit if you ask me.
2011 1SS/RS LS3 CGM
Old 07-27-2017, 11:05 PM   #10
strykerg8gt
Drives: 2009 Pontiac G8 GT
It's 54. With PEMDAS both multiplication and division are same level operations meaning you perform them left to right if they follow immediately after each other. Same goes for addition and subtraction.
strykerg8gt is offline   Reply With Quote
Old 07-27-2017, 11:29 PM   #11
jrhagen
Drives: Camaro
I am going to enjoy reading the responses tomorrow morning.
Old 07-28-2017, 01:18 AM   #12
Fondue Wormhole
Bad Example
Drives: Camaro SS
"It is not of the essence of mathematics to be conversant with the ideas of number and quantity" ~ George Boole
Fondue Wormhole is offline   Reply With Quote
Old 07-28-2017, 06:45 AM   #13
pyroguy
Keeper of “THE list”
pyroguy's Avatar
Drives: ABM #832
It is 54. Multiplication and division are interchangeable in order as long as you're going left to right. So 36/2=18, 18*3=54.
Check out my build thread
Old 07-28-2017, 08:35 AM   #14
ljc
ljc's Avatar
Drives: 2ss Nightfall Grey
Funny that you pose this question...this has been going on for the past 2-3 days. The answer is 54, but if it's "viewed" incorrectly...then the answer is 6. The parenthesis is what's causing the confusion. Normally you'd solve the parenthesis 1st, but there is no problem inside of the parenthesis...just a number.
ljc is offline   Reply With Quote
