07-18-2017, 09:41 AM | #1 |
Drives: 2015 Camaro LFX A6 Join Date: Nov 2015
1LE Struts
Anyone know the part number(s) for these?
Also, are there any modifications (new mounts, etc) that I need to put these on my car? I don't want the entire 1LE track package, as I have other custom suspension work done by JPSS.
Cold Air Inductions CAI : Apex Air Scoop / WW Relocate Kit : JacFab Intake Manifold Spacer : Overkill 80mm Throttle Body : Overkill Tuned : MagnaFlow Cat-Back Exhaust : Elite Engineering Catch Can : ZL1 Strut Tower Brace : Custom Tunnel Brace : JPSS Caster Locks : JPSS 32mm Rear Sway Bar : JPSS Billet Radius Arm Bushings : Pegasus Solid Sub Frame Bushings : 1LE Brembo Conversion : B&M 70273 Trans Cooler
07-18-2017, 09:45 AM | #2 |
Drives: 2014 1le 1SS CRMT Join Date: Apr 2014
Why not just go the BillStein route?? Think if I didn't have a 1LE that's what I do
07-18-2017, 09:47 AM | #3 |
Interesting. I realize the quality of Bilstein but wasn't sure of the cost compared to 1LE or the difference in stance that it may have. I cant say that Ive seen a Camaro on Bilstein's (knowingly).
Would definitely appreciate more peoples opinion on this.
07-18-2017, 09:57 AM | #4 |
Right no bro !! Either way you can't go wrong you'll be happy . I think the cost difference is like $150-$250. I think ??? I just paid $427 shipped for my new rear 1LE shocks and I believe like $85 each front strut less then a year ago !
07-18-2017, 10:02 AM | #5 |
JPSS actually appears to have a nice deal on Bilstein B6 at ~$840, free shipping.
Can someone tell me if these are a direct swap with a stock V6 setup?
07-18-2017, 10:46 AM | #6 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Ask Pete.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
07-18-2017, 01:18 PM | #7 |
Drives: 2015 2SS 1LE Join Date: Dec 2011
I will be at JPSS first weekend in August getting my 1LE struts and springs removed. Pete is doing the B6 struts and DSE 1.5" lowering springs.
My 1LE struts and springs will be up for sale after that. Driving from JPSS to Michigan and then to Florida so can drop of in between to save shipping. My factory struts and springs will have roughly 18K-19K miles. |
07-19-2017, 07:34 AM | #8 |
Confirmed with JP that they do fit.
07-19-2017, 05:28 PM | #9 |
Drives: 2015 SS/RS 1LE Join Date: Dec 2014
Are you going to change the springs when you install the struts/shocks? Either way you go, 1le or Bilstein you will have a nice set up. The Bilsteins are better than the 1le's but you will pay a little extra. Are you doing the work yourself? Might as well put in 1le/ZL1 or Z28 RUCA bushings? You'll have most of the suspension unbolted/unsprung and will be getting an alignment anyway. I put in the Z28 bushings, if you want my 1le/ZL1 RUCA's(9k mi) $50 plus shipping?
07-19-2017, 09:40 PM | #10 |
Emerald Coast Camaros
Drives: 2013 2SS/RS L99 Join Date: Dec 2013
B6s
Pete hooked me up with a nice set of B6s and they are way better than the OEM SS ones. I installed them with my BMR 1" lowering springs and cut the rear bump stops down 1" also.
07-20-2017, 08:45 AM | #11 |
Drives: Camaro Justice Join Date: Jun 2007
07-20-2017, 10:19 PM | #12 | |
B6
