07-17-2017, 05:16 PM | #1 |
Drives: 2010 Camaro 2SS Join Date: Jun 2017
I hate my speakers!!! What can I do?!
I got the stupid boston acoustics, the front right passenger speaker rattles like a bitch!!
I ordered a used 1 of eBay, just replaced it and same ****ing rattle, what a waste of money. Can I jus change with any speakers? Or will I have to change everything because it's the Boston acoustic set? |
07-17-2017, 05:19 PM | #2 |
Drives: 2011 2SS/RS M6 Join Date: Oct 2015
I would be inclined to think that it is not the speaker that is rattling but more likely something in the door or door panel. Having said that you can put whatever you want in there.
07-17-2017, 05:25 PM | #3 | |
Nah man, it's the speaker... I have it just hanging freely and I can hear the speaker rattle it self. |
07-17-2017, 05:25 PM | #4 | |
376 cubic inches of fun
Since the OP's rattle was not solved by replacing the speaker, the problem is probably not with the speaker. |
07-17-2017, 05:29 PM | #5 | |
I hear what you guys are saying, but I literally have the speaker in my hand with music on and I can hear it coming from the woofer inside both speakers |
07-17-2017, 05:40 PM | #6 |
The speakers will make an odd noise if they aren't securely mounted. I wouldn't have put a factory speaker back in anyway, they are pretty cheesy, even the "high end" speakers. Maybe it's time for an upgrade with amplifiers and all.
07-17-2017, 05:52 PM | #7 | |
I didn't want to put the factory 1 back in, but I read on here if I wanted to upgrade the front, I have to upgrade all? Is that true? |
07-17-2017, 11:51 PM | #8 |
Drives: 23 LT1 / 19 Z06 / after 6 5th gens Join Date: Jan 2014
Cut outs and straight pipes. You'll never hear that damn speaker rattle again.
"Make yourself sheep and the wolves will eat you"
07-18-2017, 12:04 AM | #9 |
Drives: SUMMIT WHITE 2SS/RS CAMARO Join Date: Feb 2008
I love my factory '10 SS stereo. Still works fine after 8 years.
07-18-2017, 02:20 AM | #10 |
Mad***der
Drives: 2010 Camaro 2SS Join Date: Aug 2016
All my speakers are blown but because I have long tubes and straight pipes I really don't care.
07-18-2017, 02:36 AM | #11 |
"BEASTM*DE"
BA speakers suck...You can replace with any type speaker...To make the system sound much better add sub woofer to cover the rattle...Definitely a major improvement...
Vengeance Racing Stage 1 Kit 575rwhp, 569 rwtq...
Rims powder coated gloss black...BFG'S Comp 2 A/S... Dual 10" Kicker Comp S Subs 1200w... |
07-18-2017, 05:16 AM | #12 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
For some silly reason....a sub makes these systems a whole different animal. You can replace with any other matching ohm speaker. If you do, I would suggest replacing as a set.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
07-18-2017, 07:23 AM | #13 |
Drives: 2002 Camaro SS SOM; 2015 Malibu LTZ Join Date: Dec 2010
Make sure that the speaker isn't blown. Many times the plastics and metal of the door rattle instead of the speaker itself. If you are going through the trouble of swapping speakers, its common practice to swap with new parts or newly rebuilt parts (to avoid doing things twice...which is more likely with used parts).
Also, figure out what you are expecting from the speakers. If you are looking for deeper bass then you may not ever be totally satisfied with the door speakers. If you want deeper bass and more driving power, then you may need to research and plan on a subwoofer and amp upgrade or addition. Its not easy planning and installing that ideal system. I've had success in the past with adding on to the existing system; You may want to seek out advice from experienced installers to figure out what you are really looking for from your speakers and system.
'08 TBSS AWD Black Granite Metallic '15 Malibu LTZ 2LZ Turbo '14 CAMARO ZL1 Blue Ray Metallic |
07-18-2017, 07:40 AM | #14 |
Drives: Camaro Join Date: Mar 2013
We have speakers?
