Go Back   CAMARO6 > Technical Camaro Topics > Audio, Video, Bluetooth, Nav, Radar, Electronics
Old 05-27-2017, 07:37 PM   #1
burnningice
burnningice's Avatar
Drives: 2016 SS Mosaic Black
Adding front camera
Has anybody installed a front camera with the factory radio? I'm a professional installer but I don't have access to any companies that make an integration device yet. I was told to reach out to NAV-TV. They offer a GM-LVDS. A peer of mine has used their stuff and says that it works great. Have any of you guys used it?
I looked into the Gen5DIY guys kit. They use a PAC module. (I sell PAC) I gave them a call and they said that they don't have anything for this application yet.
Its the same price at the guys at Gen5DIY but you don't have to send in your radio. I don't like having my car down to send my unit in. Thoughts?
burnningice is offline   Reply With Quote
Old 06-03-2017, 08:24 AM   #2
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
That would be awesome to have a front (and possibly side) cameras integrated into the factory unit, but to me it's not worth voiding the warranty over.
Old 06-03-2017, 08:26 AM   #3
burnningice
Im not sure how it would void the warranty if it's a plug in box. I would make the box easily removable so if there was a problem I could return it to stock.
Old 06-03-2017, 08:53 AM   #4
SuperSound
SuperSound's Avatar
Drives: '17 Camaro 2SS A8
My understanding is the box for camera integration is only one part of the issue. You need the firmware on MyLink updated so you can have an app to launch it. That's why gen5diy needs the radio sent in and why you would lose the warranty.
Sent from my SM-G950U using Tapatalk
Current: '17 2SS Hyper Blue, A8, MRC, NPP
Past: '99 SS Camaro A4, '73 Camaro 383 A3
"Voices in your head are not considered insider information."
3800 Status - 6/16/16 (Built!)
6000 status - 6/29/16 (Delivered!)
SuperSound is offline   Reply With Quote
Old 06-03-2017, 05:07 PM   #5
burnningice
I'm going to try the NAV-TV unit. It does not require me to send my unit in therefore it can't void the warranty. I will let you guys know if it works out.
Old 06-03-2017, 07:13 PM   #6
SuperSound
SuperSound's Avatar
One, did you talk to someone from their support team? No Camaro model is listed as working with the device you listed.
Two, maybe gen5diy can shed some light but this kit looks like a video intercept device designed for using a backup camera. So it plugs in between the backup camera output and myLink screen, then piggy backs it's video output on to it. Essentially only working for you when you have the shifter in reverse. I saw the instructions mention hitting Home and Menu buttons will force the display (which you would need to for a front camera), but it may only work on the vehicles they list.
Old 06-03-2017, 08:06 PM   #7
burnningice
I talked with their support team. They said that it will work with the camaro as long as it has the larger screen.
Old 06-03-2017, 08:07 PM   #8
burnningice
I believe the part number is GM-LDVS
Old 07-11-2017, 03:12 PM   #9
AWNOLD
Drives: 2017 SS 1LE
Any luck with this?
AWNOLD is offline   Reply With Quote
Old 07-11-2017, 03:40 PM   #10
burnningice
I'm working on one right now. I'm using dash connect plus.
Old 07-12-2017, 05:07 PM   #11
burnningice
I wanted to post of my front camera installed. I just want to warn anyone that wants to do this. If you are going to use a backup camera to do this, make sure that you can flip the image orientation on the screen. Most cheap cameras can flip but most expensive cameras can't. The kenwood cmos-230 is a great camera but won't work because the image cannot be flipped.
Old 07-12-2017, 07:55 PM   #12
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
How does it install? How do you switch to the from camera? Shows on mylink screen?
-Bobby
2017 ZL1 M6 Bog City, 2013 ZL1 M6, 2010 2SS M6
ZL1::J-E-T-S JETS JETS JETS
bobby35ny is offline   Reply With Quote
Old 07-12-2017, 08:10 PM   #13
burnningice
Well the brand that I have is pretty easy ( relatively speaking) it uses a t harness and intercepts the display going to the radio face. It's activated by holding down the back button. It also offers side camera inputs. I don't want to name drop right now. Once I feel that the system will work flawlessly, I will. They are still working out some Kinks.
Old 07-12-2017, 10:17 PM   #14
Hyper16
A Heartbeat Away.........
Hyper16's Avatar
Drives: Not As Fast As I Would Like To
2016 Hyper Blue Metallic 2SS | A8 | MRC | Sunroof | Nav | Mishimoto Catch Can | GM CAI | Hurst Shifter | Borla S-Type Exhaust | Body Color Splash Guards | 1LE Splitter | GM Dark Tail Lights | ZL1 Third Brake Light | Custom Fuel Door, Badges & Bowties | Oracle Side Markers | Blacked Out Stuff | Opti-Coat Pro+
The problem with this world is stupidity.
I'm not saying there should be penalties for stupidity,
but why don't we just take the warning labels off everything and let the problem solve itself.
Hyper16 is offline   Reply With Quote
