05-06-2017, 08:18 AM | #1 |
US Veteran
Drives: 2011 Silver Ice Metallic 2SS/RS A6 Join Date: Jan 2011
JPSS rear sway bar install help?
Help! This won't work, lol. Same on both sides. The bar came with 2 different sized bushings and I used the ones that were closest to the stock ones, the smaller set.
My car is lowered 1" on Koni orange shocks. I maybe should have cropped the picture: the bar is hitting the body mount, at rest. Sent from my iPad using Tapatalk
Dear Lord, give me the strength to carry on despite my Camaro addiction!
JRE iTSX tune, full cat-less Dynatech exhaust, CAI intake, Stillen Slotted/Drilled Rotors, RB braided brake lines, BMR lowering springs, (reserved for definite future MODS) |
05-06-2017, 08:22 AM | #2 |
US Veteran
Maybe this helps?
05-06-2017, 08:33 AM | #3 |
US Veteran
Here are the instructions. I don't believe it's upside down or backwards but I could be wrong. And the shaft end links could be wrong, I went from 2011 style to 2012+ style (straight) and I wasn't sure how they went. I mean there's only 2 holes, 1 in the shaft and 1 in the LCA. But I could have the pieces out of order or something. And I also put the nut on the bottom but I can't see that making a difference like this but again, I'm not sure.
JRE iTSX tune, full cat-less Dynatech exhaust, CAI intake, Stillen Slotted/Drilled Rotors, RB braided brake lines, BMR lowering springs, (reserved for definite future MODS) Last edited by OmniCamaro; 05-06-2017 at 10:02 AM. |
05-06-2017, 10:13 AM | #4 |
Drives: 2015 2SS 1LE Join Date: Dec 2011
Email Pete directly for a quicker response!
05-06-2017, 10:56 AM | #5 |
US Veteran
Yep, did that. I figured they'd be "off" for the weekend and wanted to see if anyone here could help before Monday. I'm not trying to blast them or anything. I'm sure it's something I did incorrectly.
05-06-2017, 10:58 AM | #6 |
Drives: Camaro Justice Join Date: Jun 2007
Flip the bar and life is good.
05-06-2017, 10:59 AM | #7 |
Drives: 2015 Z/22 Join Date: Aug 2015
If the bar is contacting the subframe mounts then the bar is upside-down/reversed - I'm fairly confident this is the case because I did the same thing lolol
Overkill/Self Tuned; Mace Camshafts; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
05-06-2017, 11:00 AM | #8 |
05-06-2017, 11:02 AM | #9 |
US Veteran
Thanks Pete! I knew it was something I did.
05-06-2017, 11:26 AM | #10 | |
05-06-2017, 11:32 AM | #11 |
CAR-DASHIAN
Drives: 2015 Ashen Gray Metallic 2SS/RS L99 Join Date: Nov 2015
Pete, and DynoSteve, are never off. Closest thing we have to a 24 by 7 vendor on the forum
PERFORMANCE: ColdAirInductions CAI, ADM Race Scoop, Cordes Performance Racing Ported TB/IM/Custom VVT Cam, WFO Milled Heads, Stainless Power 1 7/8" LT/3" HFCs, JBA 3" Comp. Cat-Back, Taylor 10.4mm Plug Wires, Tim King Performance Stage 3 6L80, Circle D Billet 3600 Stall, Nic D ECM/TCM Tune, - 458rwhp/413rwtq (prior to PIM), Forgestar F14 (F)18" / (R)17" Rims.
SUSPENSION: Z/28 Rear UCA Bushings, Carlyle Racing LCA/TA, BMR Adj. Toe Rods/Xtreme Anti-Roll Bar, Justice Pete Castor Locks/Radius Rod Inserts, Pegasus Billet Rear Cradle Bushings, Mickey Thompson Street SS II 305/45/17 tires. |
05-06-2017, 08:10 PM | #12 | |
US Veteran
The removal instructions are great. The rear install, not so much. I hope I was supposed to use that lube on everything, lol.
05-06-2017, 08:27 PM | #13 |
CAR-DASHIAN
Is that code???
